Question about HP ProLiant DL185 G5 Server
What smartstart versions do i need on hp proliant dl185 g5 server? what smartstart versions is compatible on hp proliant dl185 g5 server? where i can get/download it? please help!!
Posted by jm_sendoh07 on
  • Anonymous Mar 26, 2014
    HP Proliant DL100 G2 SmartStart 4.9 download required
Marius Filo
  • 127 Answers
  • Sharmila Mar 26, 2014
    I have looked in that location and the software is not listed. Thank you
Download smartstart 4.9
http://h20566.www2.hp.com/portal/site/hpsc/template.PAGE/public/psi/swdHome?sp4ts.oid=344318&ac.admitted=1395871841760.876444892.199480143 Drivers Software Firmware for HP SmartStart Software
Mar 26, 2014 | HP ProLiant ML150 G5 Server
Bios reset
Try take the CMOS battery out for a few hours.
Feb 20, 2013 | HEWLETT-PACKARD HP ProLiant DL185 G5 - 1x...
Server won't start HP ML350 G5
Reseat the drives, but DO NOT swap slots. Keep exact, in case of RAID configuration.
Use the Smartstart disc. It may show you the current array config.
Oct 23, 2012 | HP ProLiant ML150 G5 Server
SmartStart has failed to load ressource files in a timely manner. please click Ok to try Again or cancel to reboot
sounds like the startup files are corrupt if it is a windows server then reboot pressing f8 to get to start options and select start windows last known good configeration
Jan 12, 2011 | HP Compaq ProLiant ML350 G5 Server
How to enter in bios to boot change sequence in ProLiant ML 530
Press F10 during post boot if you have smartstart installed in the partition. If not, you need to boot from SmartStart CD.
May 08, 2010 | HP Compaq ProLiant ML530 Server
I want to start with New HP PRO ML370G5 Server with 2 HDD already plugged in but not configured...its going to be the very first time to confiure this server.Pls help me how to configure it with Array 400...
You will need to start with the HP SmartStart CD. If it did not come with the server, you will need to go to HP's site for that server model and download the image, burn to disk and boot from that CD (or DVD). The HP SmartStart CD should help you recognize partition and RAID-configure your drives, and begin the Windows (or other OS) installation process.
Feb 07, 2010 | HP ProLiant ML370 G5 Server
I have HP ProLiant DL360 G5 Server i found
For Server-HP Proliant , Boot using SmartStart Cd(if you don't have download iso image from HP support site--Free & burn it to media)
Now boot using this Smartstart cd and choose Maintain Server...Use Diagostic options..to check hardware.....Also check Drives status....if amber light
Replace hardware or it is Contact HP for any hardware issue
Oct 05, 2009 | HP Smart Buy HP ProLiant DL360 G5 (2x)...
Can install Win2003 server
I am sure you can find one at www.hp.com. It is better than the floppy because it will also load all of the other drivers you need.
However, if you want to save some time you could pull a floppy drive and cable from a workstation.
You can open the server case and connect the drive for the purpose of loading your RAID drivers and pull it once they are installed.
I am pretty sure that most server MBs and power supplies still have a floppy connectors on them.
If this helps please vote for my solution.
Aug 26, 2009 | HP ProLiant ML150 G5 Server
I need driver hp proliant to install
If you are installing an OS from scratch, download the Proliant SmartStart CD for your server from HP. You simply boot from this CD and follow the instuctions to load your OS. Smartstart will configure your drives, pre-load drivers, and gracefully pass control over to the OS installer.
Jun 09, 2009 | HP ProLiant ML110 Server
HP ProLiant DL185 G5 Server  Logo
1,046 people viewed this question
Top HP Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
