There are some tips to make the print quality higher:
1. Use photo paper. Photo paper often makes a huge difference in your print quality. Image and words printed on this kind of photo paper will look much clearer.
2. Change your printer settings. For the best quality, you may choose a higher printing quality printer, and get some higher quality settings to it. After clicking on the "print" button, a panel will pop up. Navigate to "Properties > Best Photo > OK" to print the best quality photos.
3. Enhance photo quality before printing. There are many photo enhancers on the market, but most of them are complicated to improve photo quality and clarify the resolution. Therefore, AI photo enhancer
would be recommended here, for it can enhance photo quality automatically.
Usually, if not all almost all printers allow you to set printing preferences before you print.
1. In windows, when you are about to print a document or photo, click preferences then you should be able to change printing quality. Usually, printers have radio buttons(option
buttons to select best "text","best quality", "photo quality" and "best photo quality". Just selct your preferences then click ok, then print.
2. If printing photos, there will be a warning to use photo paper instead of the usual paper.
3. Did this answer your question?
SOURCE: prints only high quality
You can also set your printer default settings to the print quality you perfer, so that you don't have to set them each time through the driver. Then you can change them on a case by case basis through the printer driver when you want to use a print quality setting that is different than the default.
