Question about Uniden D1680 Cordless Phone
HOW DO U CONNECT THE HANDSET TO THE BASE.ALREADY TRIED THE REGISTER BUTTON,DID NOT WORK.IT CAME WITH NO DIRECTIONS,WE BOUGHT AT A FLE MARKET FOR 5 DOLLARS.
  • Uniden Master
  • 6,199 Answers
Are you sure of the model number? The D1680 should register the handset when you put it on the base for 30 seconds. (You should see Handset Registering followed by Registration Complete.) Then press Talk/Flash to check for dial tone. On this model if the registration fails, charge the battery (or replace the battery and then charge that). Then repeat the registration.
The manual for the Uniden D1680 is available here: http://news.uniden.com/pdf/D1680om.pdf .
For other Uniden phones, like the DEC1060, you need to navigate through the handset menus to find the Handset Registration command. Then press and hold the Register Handset (Find Handset) key on the base for 3+ secondsThen the base and handset will synch. (Low batteries could interfere with the process.)
For the D3288, you access the base menu for Register Accy and then press and hold # on the handset for 30+ seconds. (You will see Registering followed by Registration Complete.)
Additional Uniden cordless phone manuals are available here: http://www.uniden.com/scat/cordlessphones_mnl .
I hope this helps.
(with a flea market phone, my first suggestion is to try a new battery for the handset. They only have a given number of recharge cycles and you do not know the history. However, sometimes the chargers do fail and a new battery will not work. In that case, the phone should be replaced. It isn't worth the cost of out-of-warranty repairs.)
Posted on Jul 01, 2011
Can't seem to deregister the used HS I bought on Ebay since I don't have it's base.
1. To de-register the orphaned handsets from their old base:
When the orphaned handset says "Connecting..." or "Out of..."
enter *331734 [menu]
and it will soon beep and display "Not registered"
2. To register the new handset to your base:
press the "Handset Locator" button on the base and hold
it until the "in use" light comes on ( ~ 4 seconds ),
then release the button and set the new handset into
the base phone cradle. After ~ 30 seconds it will beep
and display "Handset #" (next in sequence).
3: Note: the base handles a maximum of 12 handsets.
If your system was fully populated ( ie, a handset is
already # 12 ) you will have to clear all the handsets
from the base and re-register them all in sequence.
( it is the only way to 'rescue' the places occupied
by the lost handsets ).
To clear the base of all registrations:
1. Press and hold the the "Handset Locator" button
until the "in use" light lights and then starts to blink
( ~ 10 seconds ), release the button --
then press it again briefly while the "in use" light
is still blinking.
2. The base will beep and all handsets that were registered
will display "Not Registered"
3. Follow the instructions above for each handset
in turn to re-register them:
press "Handset Locator" ~ 4sec ( in-use light on ),
set handset into the base cradle, etc.
The manual is available from: www.manualslib.com
but does not fully describe these procedures.
Good luck !
Nov 27, 2015 | AT&T DECT 6.0 Expansion Accessory Handset...
Can not register handset
The handset must be de-registered before it can be registered.
Try this:
1. To de-register the handset from another base:
"Out of Range..."
is still blinking.
Good luck !
Nov 22, 2015 | Vtech AT&T CL83213 2 handset cordless...
Hand set says connecting even before it is reset with new base.
This sounds like a registration problem, each 'old'
handset must be de-registered from its original
base and then registered to the 'new' base.
NOTE: the CS6229 handles a maximum of 5
handsets. If you have a handset displaying
"Handset #5" then you have a 'fully populated system'
even if you actually have only one or two handsets.
You will need to clear each handset ( I ) then clear
the base of all registrations ( II ) before re-registering
each handset ( III ) up to the maximum of five.
( I ). First, to de-register a handset ---
0. Start by taking off the battery compartment cover.
1. press [menu]
2. scroll up/down to "Settings"
3. enter * 7 8 9 0 #
4. scroll down to "next page", press [select]
5. scroll down to "Register Clear?", press [select]
6. display asks "Confirm?" or "Register Clear??",
press [select]
7. display reads "Ok" and chirps, press [ off ]
8. UNPLUG THE HANDSET BATTERY
(this is why the cover was off)
9. Wait ~30 seconds, re-connect the battery &
replace the cover
10. display reads "Not Registered"
( II.) To clear the base of all handset registrations
( if needed, else skip ahead to ( III ). )
1. press [Find Handset] on the base and hold
past ~4 sec when the "In Use" lamp lights, at
about 10 secs the "In Use" lamp will begin to
blink. 2. release the [Find Handset] button momentarily,
then briefly press it again. After a moment,
all handsets that were registered to the base
(if any) will display "Not Registered" and be
ready for fresh registration ===============================
( III.) To register each handset to the base:
1. press [Find Handset] on the base and hold for
~4 sec until the "In Use" lamp lights.
2. press # on the handset and set the handset into
the handset cradle on the base
3. within 30 seconds or so, the handset will either
chirp and display "Handset Registered", then
"Handset #x" or it will say "Registration Failed".
NOTE: the battery must be well charged prior to the
registration process, a weak battery may cause a
"Registration Failed". Charge the battery for a
few hours and try the registration ( III ) again.
Good luck !!
Jul 23, 2015 | Vtech Lands Phones
Hi, I have a DECT2085-3 base with 3 handsets. I would like to add another handset. I bought two used handsets and would like to register them to my original base. I am having trouble with the selecti
In the instructions you need to find how you Sync the base and add that number phone to the base. All have different ways so try the company website on google.
Dec 09, 2014 | Uniden DECT2085-3 Trio Cordless Phone
Have a DS6222-4 - bought 2 handsets to replace 2 that have the names of the buttons worn off. Charged the new handsets overnight - screen says "Connecting..." even though they are right next to the base....
If they (hand-sets) have already been synced to a base...
The preferred way is to UN-sync from their OLD BASE.
The manufacturers are SMART ENOUGH to realize
the bases & remotes may not ALWAYS remain associated.
You must first UN-REGISTER any association with their
PREVIOUS EXISTANCE... before you can register these on your base...
Likewise... you WILL BE A LOT HAPPIER if you
UN-REGISTER the REMOTES you are planning
to retire
The numbers are quoting are wireless (remotes).
DS6222-4 Wireless handset Manual:
Results 1 8 of 8
You should also look at the instructions for
your (wired) BASE.
There are at least two ways for EVERY TASK...
(you only need one (your choice)).
Carnac the Magnificent
Jul 01, 2017 | Vtech Lands Phones
Vtech cordless handset CS6209 will not connect with CS6229-2 base
Yes. The'old' handset must be de-registered from its
original base and then registered to your base.
1. press [menu]
press [select]
replace the cover
Good luck !! --
Jun 08, 2013 | Vtech Lands Phones
Deregister procedure for at&t el52400 handsets
is still blinking.
Good luck !
Mar 21, 2013 | AT&T Lands Phones
Base el5200 will not reconize new hand set
To deregister the new handsets from their old bases and re-register
them to your base, try this for each new handset...
1. When the new handset says "Connecting..." and goes nowhere
else, enter *331734 [menu] and it will soon beep and display
"Not registered"
2. To register the new handset to your base: on the base press
the "Handset Locator" button and hold it until the "in use" light
comes on ( ~ 4 seconds ), then release the button and set the
new handset into the base phone cradle. After ~ 30 seconds
it will beep and display its "Handset #" (next in sequence).
3: Note: the base has a limit to how many handsets it can handle,
I believe it is five handsets maximum for the EL52300.
If your system was fully populated ( ie, a handset is already # 5 )
you will have to clear all the handsets from the base and
re-register them in sequence ( it is the only way to 'rescue' the
places occupied by the lost handsets ).
1. Press and hold the the "Handset Locator" button until the
"in use" light lights and then starts to blink ( ~ 10 seconds ),
release the button -- then press it again briefly while the "in use"
light is still blinking.
2. The base will beep and all handsets will display
"Not Registered"
3. Follow the instructions above for each handset in turn: press
"Handset Locator" ~ 4sec ( in-use light on ), set handset into
but does not describe these procedures.
Good luck !
Mar 01, 2013 | AT&T ATT EL52500 DECT 6.0 5-Handset...
My uniden DSS7855 with 1 base station and 3 handsets wont connect when i dial a number and hit the talk button it tries to connect and then comes up "'out of range" much appreciated for any help...
Clear the Handset's Base Data
  1. To remove the base data from a handset when out of range of the base, press and hold the 'end' button and the '#' button simultaneously until the phone beeps.
  2. It will now be de-registered from the base.
Note: This requires that the base and handset can communicate with each other.
Clear the Base Handset Data
  1. To de-register all handsets from the base, remove power to the base, and remove the handset from the base.
  2. Press and hold the 'flash/find hs' button while applying power.
  3. Wait for the beep and release the button.
  4. The charge light will now flash.
  5. Sit any handset in the cradle.
  6. When the flashing stops, re-register the handsets to the base.
Re-Register a Handset to the Base
1. Remove Handset Battery.
2. Reconnect battery while holding down "*" and "#" key.
3. Then press the right upper key under the LCD.
4. Press the "End" key.
5. Wait a few seconds and then the phone will be ready to register to the base.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Nov 12, 2010 | Uniden Lands Phones
Validation
I would assume this could have been a product that was returned to the company that you purchased it from. Follow these instructions. 1. 1. Disconnect power from the base by pulling the plug out of the back of the unit. 2. Press and hold the Page button and while holding the Page button reconnect the power. 3. Continue to hold the Page button until the charge/in use light flashes rapidly. 4. Release the Page button. 5. Press and release the page button on the base once. All handsets are de-registered and HANDSET NEEDS REGISTRATION shows in the display. Then From the Handset Setup Menu: 1. Press the caller ID-volume ( 6 or 5) button to scroll to the REGISTRATION sub-menu. 2. Press the mute/program button to enter the menu. REGISTRATION 1YES 42NO - - -shows in the display. The default setting is 2NO. 3. Use the touch-tone pad to select 1 for YES or 2 for NO. Or use the caller ID-volume ( 6 or 5) button to scroll to 1YES or 2NO. 4. If you select YES, press the mute/program button. HOLD BASE PAGE FOR 5 SECONDS, THEN PRESS HANDSET PROGRAM shows in the display. (Your handset should be held near the base during registration process.) 5. Press and hold the page button on the base unit until the charge/in use indicator flashes. Press the handset mute/program button. REGISTERING shows in the display. HANDSET X REGISTERED shows in the handset display, where X is the handset number. You may now rename your handset. (Refer to Step 3 & 4 of Handset Name Section) NOTE: IF you are re-registering the handset through the handset menu; to rename your handset you must go to the Handset Name Section and start from the beginning step. I understand that you have tried the registation process. Sometimes with electronics, you have to start from ground 0, before it will work correct again. If there are further questions or comments, please post here. Please rate this solutn through fix-it. Thank you
Jun 22, 2007 | GE 28111 Cordless Phone
Uniden D1680 Cordless Phone Logo
1,146 people viewed this question
Top Uniden Lands Phones Experts
k24674
Marvin
Marvin
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
