Question about Dell Inspiron 1525 Notebook
If I turn the computer off and then turn it back on, the screen sometimes remains black. After turning it off and then on about 20 time the screen will finally come back on and the computer will run fine until it is turned off again and then the entire sequence is repeated.
Posted by mdw1941 on
tchav12
Just be patient when it turns black. it will turn on. Try reducing theamount of icons on your desktop and check memory space and unload if over 80%
Posted on Jul 01, 2011
Should I replace Monitor?
Your monitor is telling you that it is time for you to replace it. Your monitor is going bad on you and will only get worse.
Mar 26, 2012 | Computers & Internet
Hi! A few months back i bought a Philips 52'' LED-TV 52PFL5605H Full-HD, 100Hz Tv to my computer and it works good. The only problem is everytime(not always. 8 out of 10 times maybe) the screen is just...
Unfortunately the video you are giving the tv must be one of the last systems the uProcessor in the tv checks. It takes about 15 seconds to detect signal/no signal for each system. Good old automated technology!
Dec 31, 2010 | Philips Ambilight 2 52 in. Flat-Panel LCD...
My screen went black, its a insignia 20'' lcd.
Generally, problems like this require repairs to resolve. You may carry the TV in to the place of purchase to pursue service options.
Mar 09, 2010 | Insignia LCDTV26 26 in. Television
IBM T61 remains with dark blank screen but is on.
Connect it to another monitor,and see if it comes on. Your screen may be damaged.
Feb 22, 2010 | Lenovo ThinkPad T61 Notebook
Laptop intermittent startup problems
if you need your laptop always in ready use change the time your computer is on in control panel then log off your device will be on always until you shut it down it constantly drains battery
There is a way to fix this try reinstalling windows
or just take it to software mechanic
Mar 21, 2017 | HP Compaq Presario v4000 Notebook
Contrast/menu/screen resolution box wont stop flashing on screen.
try to clean around it's exit button sounds stuck
or unplug monitor for about 20 minutes
if the problem persists i would reinstall driver
Jan 09, 2009 | E-Machines eMachines Desktop PC
My screen randomly blacks out.
the best method to overcome this problem is format the computer!!! i too used to get the same problem!!i did format it...!
Dec 30, 2008 | Microsoft Windows XP Professional
Lcd monitor failure
your monitor need to be service so take it to service center if you are in mumbai you can call for service
Ashok
9322133048
Nov 11, 2007 | HP Compaq FP5315 15" LCD Monitor
RE:monitor goes black
Monitor going black after a few seconds can be causd by a faulty power supply or inverter. Some monitors have both as one unit.
Sometimes it is basic failed capacitors, After that then I would look at transistors.
The average monitor from 17 to 20 and sometimes the 22s have usually 4 bulbs in them. One bad bulb will also cause the inverter to not fire up.
Bad bulbs usually show pinkish tint, or flickering or are dark at center top or bottom of the display.
ebays bammbammfran
Sep 21, 2007 | Acer AL2017 20" LCD Monitor
Dell Inspiron 1525 Notebook Logo
90 people viewed this question
Lee Hodgson
Lee Hodgson
Ekse
efs_perpends
efs_perpends
