Maytag Dishwasher Logo
Question about Maytag Dishwasher
I have a GE Dishwasher Model: PDW7800G00BB and when I close the door it trips the breaker on the Breaker Panel. What would cause this?
Posted by dale_senter on
Steve Allison
  • Maytag Master
  • 5,569 Answers
Check the breaker carefully, it may have a GFI (Ground Fault Interrupter) built in. If it doesn't say anything about this on the breaker, look for a small 'test' button which is used to test the breaker's reaction to a fault condition. If it is GFI equipped, water has gotten into areas where it did not belong and is causing ground currents to flow activating the GFI.
If it is not so equipped, then the motor has probably failed drawing excessive current causing the breaker to trip.
Posted on Jun 30, 2011
The start light is flashing on my GE dishwasher?
What's the model number? How old is this dishwasher? The new GE dishwashers (less than 3 years old) have a weakness in the door switch/latch assembly, and that would cause the light to flash - it wants you to press Start and close the door, but it's not recognizing that the door is closed.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Where are the fuses in the nautilus dishwasher
I do not believe there are fuses inside the dishwasher.
When the Use and Care Manual mentions a fuse (Fuse is blown, or the circuit breaker tripped), it is referring to the Fuse Panel/Circuit Breaker Panel.
What problem are you experiencing?
Kudi02cr Kitchen aid dishwasher not turning on. No lights nothing
check your breaker panel to see if the dishwasher breaker might be tripped. then be certain that the door is closing all the way and engaging the safety switch
Jul 04, 2014 • Dishwashers
Asko d1756 power trips when door is closed
The switch in the door may have a bare wire touching the sides causing a short. Check a schematic for the proper way to remove and test the switch. Look for bare wires or any insulation cracks.
Mar 15, 2014 • Dishwashers
Dishwasher trips breaker. Breaker only resets of door is opened
wires rubbing inside dish washer , surprising its not blowing fuse in dish washer plug .
Mar 25, 2013 • Dishwashers
1helpful
2answers
GE microwave (Model JE2160SF03) trips breaker when door opened
Remove the control panel, take pictures of the door switch wiring while they are still connected to the door switches, then remove the door switch assembly. Have someone at the appliance store check each switch and repair the ones that are defective.
I purchased a switch for $7, reinstalled the door switch assembly and the microwave is working fine now.
2helpful
2answers
Hi! My Bosch began by tripping the breaker during the cycle (several times if I could get it to reset) and now will not start at all. Even when the dishwasher is off I cannot reset the breaker unless I...
Hello
Welcome to Fixya.
Based on your post,"...Even when the dishwasher is off I cannot reset the breaker unless I kind of move the machine around a bit. Sometimes it pops the breaker just closing the door..."
These are the most common reason for these Bosch dishwashers not having power.
#1
I would start by first shutting off the breaker. Then removing the kick plate ( access panel at the bottom ) and checking the wiring at the junction box for the dishwasher 120vac supply line.
Remove the murret's and visually inspect the wire for "resistance burn" and strip the wires back and install new fastener's if necessary to repair.
i.e.
This is actually quite common to find a wire connector come loose due to improper fastening and once the unit is in use for a while the connections heat & cool, become loose from normal operating vibrations and burn up from all the added heat caused by "resistance".
#2
A wire severed inside the door panel, hence the breaker trips by just moving the door in an open/close motion.
Check thoroughly in this location...
The end result is tripping the breaker and no power to the controls.
Check it out and post back what you find. Thanks for visiting "fixya" and please take a moment to rate the solution/suggestion provided here for you.
Good luck.
Regards,
Macmarkus :)
Circuit breaker trips when dishwasher is off.
the problem will be in the circuit to the door
opening the door and it trips the breaker indicates that the hinge is rubbing on a wire or making the harness move to ground out
2answers
GE Max dishwasher no lights on panel
I have the same problem and actually found a workaround by mistake you may try as a temporary solution (if that works for you):
- press and hold the lock button for a couple of seconds
(the delay timer would increase by 1 hour)
- press and hold the lock button again
- repeat until it reaches 9hrs
- repeat one more time: the control panel should be functionnal again.
Let me know if that worked for you!
Feb 04, 2008 • Dishwashers
Top Maytag Dishwashers Experts
Mike
Marvin
Marvin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
