This is a protection method used to prevent badly coded scripts or overly large scripts from tying up your MAC. If its just the one website that this happens on, I wouldn't worry about it. Safari is a bit more picky with slow scripts then other browsers. Try downloading firefox internet browser and load the problem webpage on that.
Regards,
Chris
You may have encountered the following message while browsing certain websites:
"Internet Explorer cannot open the Internet site http://<website>.com. Operation aborted."
This really has nothing to do with your browser or your computer. You get this error because of faulty web coding from the webmaster's end.
IE displays this error when it is unable to open a particular element on a web page.
There are many things you can do to troubleshoot this kind of problem.
Upgrade Internet Explorer.
This problem does not occur in Internet Explorer 8. Navigate to Microsoft download Center and click on the "Download" button to upgrade to IE8 or IE9 (see Below).
http://download.cnet.com/windows-internet-explorer-8/3000-2356_4-10910662.html
IE 8
http://www.microsoft.com/windows/internet-explorer/default.aspx
IE 9
Click on "Tools" and select "Internet Options." Hit the "Advanced" tab.
Click to remove the check mark next to "Show friendly HTTP error messages" under "Browsing" sub-headings.
Click on "Apply" and hit "OK." Please note this works mostly for Internet Explorer 6, although there is no harm in trying this on older or newer versions.
Add the specific website that is producing "Operation aborted" error under "Restricted Sites."
Click on the "Security" tab under "Internet Options."
Single-click to highlight "Restricted Sites."
Hit on the "Sites" button and click on "Add."
Type the URL of the website and hit "OK."
This works for Internet Explorer 7, but again, you can try this in earlier versions.
Disable or require prompt for "Active Scripting" when you view the specific website.
Click on the "Security" tab.
Click to highlight 'Restricted Sites" zone.
Navigate down to the sub-heading "Scripting."
Click to select "Disabled" under "Active Scripting."
You may also choose "Prompt" if you want IE to issue a prompt when opening the specific web page or website.
You can run a free registry scan using utilities from http://re7.info
If you are still worried about the registry or need to fix any problems with it
Hope this helps.
In most cases, you can ignore them. Script error messages are
displayed by Internet Explorer when there is a problem with the JavaScript
or VBScript
code on the website you are viewing. Occasionally a script error can be caused
by an error in downloading a webpage, but more often it is an error in the
webpage itself.
To be sure it isn't an error in downloading, click the Refresh button, or press F5.
Internet Explorer refresh button
If the error persists, and you are not a developer testing a
website, you should click No to ignore the error.
To avoid script errors in the future, you can turn off script
debugging and notifications in Internet Explorer. Script error debugging and notifications are turned off by
default. If they have been turned on, follow these steps to turn them off
again.
Click the Tools button, and then click Internet Options.
