Question about Logitech LX5 Cordless Optical Mouse
Moves very slowly and sometimes stops-new battery installed
Posted by snctygl3 on
Matson Kurian
    Scholar:
  • 175 Answers
Please a white paper and move
Posted on Jun 30, 2011
1helpful
Battery drain will take jump off but it shut down when cable is removed from battery ( new batt & alt. What can it be?
if this is a what I refer to as newer model vehicles 93 to 95 and up if you disconnect the battery cable while it is running it kills power to the computer and the car will shut down, it can also fry the computer. That is something that you could do a really long time ago, but now can cause expensive damage. I would suggest taking car to Auto Zone or Advance. let them check the battery and alternator even though they are new.. I cant tell you how many new alternators fresh out of the box I have installed and were defective. same can go for batteries they sometimes can sit on a shelf 6 months before being sold and can start to break down and they will not hold a charge. if they both test ok. you need to check for a parasitic drain. I believe Auto Zone will do that for you for free like the battery and alternator test. if not take a multi meter,,put leads on battery and see if voltage is slowly dropping over a period of an hour or two. then you can start removing fuses one by one and see if voltage drop stops.. if say radio fuse stops it,, you know there is a short or problem with the radio,,
What is the starting procedure?
Start with the choke on full press the fuel siphon button till the lines are full of fuel. pull handle until it tries to start but stops. move the choke to half then start again. let it run for 60 seconds on full. don't move the choke to full or it will stop. Either slow the revs and then put the choke on full or keep the revs high and slowly move the choke to full (to allow the governor to slowly advance with the new revs)
I have replaced battery on my tag heuer 200m professional but it keeps stopping. It will run perfectly for a few minutes or hours then stops. If I unscrew the back case it seems to run ok, bad connection...
did you try installing an other battery ,sometimes batteries are no good.
But your problem can be several things, including battery, or installation of battery not done properly.
Another issue might be that the watch hands have moved and are bumping into each other and stopping the watch from moving. Check the hands and see if they are touching when you turn the crown.
Another issue might be that your movement might be dusty or dirty and will need to be cleaned out. It happens and depending on the age its another likely cause.
Those are the easy fixes and most common causes.
Other issues involving taking the watch apart or fixing / replacing the coil spring.
Jan 23, 2012 • Watches
Cordless Sawzall #6515-20. Cutting with it and it just stopped. Changed battery no go. tried moving the blade manually and it moved slowly a little and that was it. Took apart and tested the switch with a...
the field unless dropped is a permanent magnet and WON"T fail. I would look at the contacts from the battery to the saw. This battery has a sometimes problem with heating up and makes contact difficult. you can usually see where the housing is distorted in the contact area. if you have tested the switch and sounds like you know how to use the meter check the continuity/resistance across the brush leads and while doing this turn the armature slowly to check for open portions of the commutator. if all good there then your power supply is the area of concern. Let me know if I can help anymore. And did you call the 1-800-sawdust number.
1helpful
Need to change fuel pump.need to know what steps to take first. believe gas tank must be dropped. just want to make sure when tank is ready to drop all other connections or screws and bolts have been...
first you disconnect the battery , chock the wheels , jack the car up use jack stands , disconnect lines and filler hose and electrical plug sometimes you have to lower tank slowly to get enough room to disconnect lines from top of tank then lower it slowly to the ground make sure you bench test the new pump before you install it sometimes you get a bad one that is stuck its better to find out before you install it hope this helps
I have just fitted new battery to my pride sonic but will only move very slowly even at maximum speed adjustment
Hi. Did you fit one battery or two new ones. It never pays to fit only one battery.
Have you checked for a high/low switch, sometimes called indoor/outdoor switch.
Check motor and battery connectors.
Check motor current ( amps ) with an amp meter to see if the motor is faulty.
Check brake unit is not causing drag on the machine.
Good luck. Neil.
1helpful
2answers
Not working
Try resetting by taking out the battery and disconnecting the receiver from USB input.
If that doesn't work try uninstall and reinstall.
Good luck.
J_inno
Irobot moving slowly
Try running th roomba with the dust bin removed to see if the main brush is turning, if not it could be an issue with the gears being stripped in the brush motor assembly or inside the brush compartment holder. If the gears are fine the brush motor itself may be blown. A new one is about $30.00.
Logitech LX5 Cordless Optical Mouse Logo
Top Logitech Computers & Internet Experts
Ekse
Mehandi Husain ...
k24674
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
