Question about HP PSC 1610 All-in-One Printer, Scanner, Copier
I have an hp LaserJet 1220 all-in-one. It still prints fine, but the copier and scanner have suddenly started producing faint scans and copies. With the scanner the on screen images are faint as well as the printed copies.
Posted by rodgers_m on
5 Related Answers
Anonymous
  • 5 Answers
SOURCE: HP CM1015 copy/scan problem
DO THIS CHECK WHERE THE CATRIDGES IS IN ORDER.OR IF IT IS LEAKING
Posted on Jan 18, 2008
Anonymous
  • 983 Answers
SOURCE: hp photosmart c6180
you are good at taking things apart and not destroying them, then the problem can usually be fixed easily.
Remove the ink carts.
on either side of the carrage there is a screw, remove both of them.
CAREFULLY slide out the silver bar those screws are holding. Be sure to note its orentation for putting the thing back in later.
also carefully remove the silver "fingers".
remove the black clip/cover on the right side of the carrage that covers the ribbon cables.
lift the head (you see 4 nipples in there-- that is the top of the head assembly)
gently pull out the ribbon cables.
on the bottom of the head is 2 screws, remove them
now the head will come into 4 parts. Nipples, Gasket, nozzle block, and a metal guard.
get some windex with amonia.
soak the parts for a day or 2.
blot dry, then let it set for atleast 2 days to be sure it is COMPLETELY dry.
reassemble, charge the ink, do the printers head cleaning, and boom. back in business.
this works 90% of the time
Posted on Feb 09, 2008
Anonymous
SOURCE: hp psc 1210v all-in-one printer, scanner, copier will not scan
CHECK BELOW OTHERWISE GO TO HP WEB SITE AND LOOK FOR THE DRIVER SUPPORT TO DOWNLOAD.
Scanning
Use one of the following three methods to scan a document. Method one: Scanning with Windows Photo Gallery
  1. Click the Windows (c01367376.gif ) icon.
  2. Click All Programs .
  3. Click Windows Photo Gallery .
  4. Click File , and then click Import From Scanner or Camera .
  5. Click Import .
  6. Click Scan .
Method two: Scanning with Windows Fax and Scanning
NOTE: This feature works only with Windows Vista Ultimate, Windows Vista Business, and Windows Vista Enterprise.
  3. Click Windows Fax and Scanning .
  4. Click New Scan .
  5. Click File , and then click Scan .
Method three: Scanning with Paint
  3. Click Accessories .
  4. Click Paint .
  5. Click File , and then click From Scanner or Camera .
  6. Click Scan .
Posted on Apr 08, 2009
Anonymous
  • 169 Answers
SOURCE: My problem is with the HP PSC 950 series printer,
faxing,scanning and copying use the same mechanism,thts the scanner,if its doing it intermittently you can try a reset on the printer.see if tht works.
Posted on Jun 24, 2009
Anonymous
  • 23 Answers
SOURCE: Copying and scanning don't work but produce all-black image
please clean the scanning glass and also the feeder.
Open the machine check if any paper has struck anywhere inside.
In most of issues it will work, if this does not works call your technician to troubleshoot the problem
Posted on Jan 13, 2010
HP LaserJet 3030 Printing comes out light but copies are fine.
Have you calibrated your printer after changing ink cartridges?
1helpful
Difference between hp printer1200 and hp printer 1220
the only difference it that hp-1220 is with the scanner attached and 1200 is without the scanner.
On the picture posted with the question is HP-1220, remove the scanner and it's talked about HP-1200
Cheers and visit us on //dentaltourusm.rs
Dental practice Mr dr Mirela Cvjetkovic Belgrade Serbia
1helpful
HP 3055 All In One laserjet prints all black pages
Odds are that you have a bad toner cartridge; especially common when using remanufactured cartridges. (Staples, Corporate Express, etc.) Replace your cartridge with an OEM HP cartridge and you should be OK.
HP LaserJet 1220: all lights are on
Hi
The complete list of the light patterns, causes and what should you do, are there on this link
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=29789&prodTypeId=18972&prodSeriesId=29789&objectID=bpl10633
it looks like this
Type of error Light pattern Recommended action No power - The printer is not connected to a power supply. c00031238.jpg Plug the printer into a power supply.
If the printer lights do not turn on, contact HP. Ready - The printer is ready to print. c00031239.jpg No action is necessary.
To print a configuration/self-test page, press and release the GObutton on the printer control panel. Processing - The printer is receiving or processing data. c00031240.jpg Wait for the job to print.
Hp2100 laserjet printer producing very faint copy
Could be a few things. I would check the transfer roller first it is the roller that sits under the toner cart. This roll should be spring loaded. Press down on each end, it should move down and come back up. If someone removed this roll the springs may be missing or out of place.
Let me know if this helps
Copier feature (Black or Color) only produces a Black page
I beleive you are not able to make a color copy, once try to scan from the computer or all-in-one to check whether the scanner mechanism is working properly or not, if the scan comes out fine then remove the color cartridge and clean the copper contacts of the cartridge with soft cotton cloth and also check the ink level of the cartridge, if the issue persists replace the color cartridge and if even the scan does not comes out good then there is an issue with the scanner mechanism.
2answers
Ben Johnson
Marvin
Marvin
