Question about HP JBL Platinum Computer Speakers
Hi, one of my speakers has a front input port what is this used for?
Posted by sshawmufc on
Justin Welsh
    Novelist:
  • 102 Answers
Input port is most likely used to play something like an iPod through your speakers. You will need a cable like this one http://www.amazon.com/Cables-Unlimited-AUD-1100-06-6-Feet-Stereo/dp/B000SE6IV8/ref=sr_1_1?s=electronics&rps=1&ie=UTF8&qid=1309461989&sr=1-1 . Just plug one end into the "headphones" port on your iPod like device, and the other into the input port on the speakers.
If this helps, please rate this answer.
Posted on Jun 30, 2011
My speaker jack broke off inside my audio input in the back of the computer. I want to use the thermaltake case's front usb and audio out/mic in jacks, but they don't seem to get power or work. My drivers...
> Have you removed the broken jack from the rear end of the pc ?
> Are you trying to use the audio ports on the front panel ?
> if you are trying to use the audio port on the front panel you will first need to remove the piece of the broken jack stuck in the rear port - cos you can take an audio out line either from the front OR the rear any one
Oct 22, 2013 | Thermaltake Mid-Tower VL10001W2Z Element G...
Hi .. i have just bought a logitech x 530 speaker and only 2 of the speaker parts work .. can you please give me some solution advice?
Hi names Rui i like to help you by giving you step by step instruction in propely hocking up your logitech speakers:
Instructions
1. Connect the black plug of the rear right speaker into the black plug on the subwoofer.
2. Connect the yellow plug on the rear left speaker into the yellow input on the subwoofer.
3. Connect the red plug of the front center speaker into the red input on the subwoofer.
4. Connect the white plug of the front left speaker into the white input on the subwoofer.
5. Connect the d-sub connector plug from the front right speaker into the d-plug connector on the subwoofer.
6. Connect the green, black and orange input to the matching plugs on your computer. If you have a four-channel sound card, connect the green plug from the input audio cable to the front plug of the card and the black plug to the rear plug. Do not connect the orange input. If you are using a two-channel sound card, connect the green plug from the input audio cable to the "Line Out" jack on the sound card. Do not connect the green and orange plug.
7. Plug the subwoofer power chord into the electrical power outlet.
8. Place your subwoofer on ground around your computer desk. Position the front center speaker on top of your computer monitor.
9. Place the left and right front speakers on the sides of the monitor. Position the left and right rear speakers behind you, making sure they are pointing toward the front left and right speakers.
10. needs to support 5.1 surround. Normally, more than three sockets for sound indicates that it does. Then you need to use the software that comes with the sound hardware to configure it for 5.1 - Default will be 2.1 or just 2.
Check the control panel out. This is a lot easier under Windows 7.- Here you can access what you need via the speaker icon on the system tray (right click)
There is NO problem with your OS or hardware, this is pretty standard...
hope this will help you solve your problem.
Jul 18, 2011 | Logitech X-530 Computer Speakers
Hi, I hve JVC TH G30 and i have connected my DishTV receiver (not HD) to the Aux port of the device. I can get sounds only on the front left and right speakers.. Is there an option to get surround for...
This is a 2-part question. You can get ALL speakers to SIMULATE a surround experience from ANY input, even 2-channel analog.
If there is an optical digital audio output on the Dish TV receiver use THAT and the TH-G30 can decode the surround audio properly.
Read up on surround modes in the manual.
Jun 07, 2011 | JVC TH-G30 Theater System
How to i connect my bose companion 2speakers to my computer and get sound
hi, first Identify what computer you have. Is It A Mac or PC?
If it is PC
There should be 2 small 3.5mm coloured sockets on the back,front (or both ) of the main box (tower/desktop unit). You should find that they are coloured Green and Red. Green is for sound output (Headphones/speakers or hifi) and the Red is for sound input or Recording. Used for things like microphones. Some will accept line sources such as mixers and Ipods pr cassette players, but please check your sound manager, mixer settings in your opperating system to make your you have an adjustable input setting for Mic and Line input attenuation as not all do and you may end up with a distorted mess. You may also find there is a small diagram of headphones or a microphone to indicate sound "in" and "out" ports.
If you have a mac
Appart fom me being envious :-) there are two sockets. On laptop types, on the side or on the tower types on the front,back or both. They have a diagram of a microphone and headphones. Hadphones is for audio output to headphones, speakers, hifi, dj mixer. The Microphone is a sound input. Please read above for microphone port usage. Hopefully this answers your question. Please also bear in mind that if you have no sound once plugged in, you may need to adjust the audio properties in the system in the system and/or program you may be using
Dec 29, 2010 | Bose Companion 2 Series II Multimedia...
Front panel connector J16 dell dimension 2350
Visit http://support.dell.com select your product and download user manual and maintenance manual. It may solve your problem.
Jul 15, 2009 | Computers & Internet
Cant find users manual for boston micro media systems 7000596 need 2 see how it is hooked up to my computer thank u
Plug red and white cables into woofer ports that are red/white
Plug purple lead into front of woofer to input port
green goes into accessory (green) port on back of computer
elbow shaped 2 prong leads go to speakers in back
DC power goes into front of woofer marked DC input
Apr 19, 2009 | Boston Acoustics MicroMedia Computer...
Have one wire for audio sub out, but two input ports to amp
This one Wire should be for the +. Try connecting the + to the Head Unit and - to a Common Ground. At the Worst, You will Blow the Amp Fuse if not Correct. The Lead from the Head Unit is Only an Off and On from the Ignition. Please Rate My Response! Thanks!
Jan 31, 2009 | Power Acoustik PTID-8960 Car Video Player
No sound from all speakers except front left and front right
Check the cables from the DVD to the Amp and make certain your in Dolby Digital mode on player.
Jan 24, 2009 | JVC TH-G30 Theater System
I have a creative 4.1 Speaker system but only Front speaker seems working???????????????
I have 4.1 creative speaker but only front 2 speaker will work
so i have connected convertor ie,2 output and 1 input then i connected to the green port so all the speaker are working.
Gowrish
Jun 15, 2008 | Creative Labs FourPointSurround FPS1800...
Speakers
Hi ozlion, I have been through the manual for your board & other than the front speaker/mic connector I have not been able to find a jumper to do what you are asking. You can download the manual for yourself at this link. http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=522&DetailName=Manual&DetailDesc=661GX/800-M%20%20(V1.0B)&CategoryID=1&MenuID=82&LanID=0
7fd7530.jpg &
f792809.jpg Only some newer boards that handel HD can play stereo front & back at the same time.
Mike
Mar 27, 2008 | EliteGroup 661GX/800-M (661GX800M7)...
HP JBL Platinum Computer Speakers Logo
Top HP Audio Players & Recorders Experts
Marvin
Marvin
Lawrence Oravetz
 Grubhead
Grubhead
Are you a HP Audio Player and Recorder Expert? Answer questions, earn points and help others
