Question about UTStarcom Cell Phones
The backlight on my gtx75 has ceased to work. is this a hardware or software problem?
Posted by frankandstei on
Can I upgrade my iPod edge iOS?(mco86ll)? Version 4.2.1?
If Settings / General / Software Update doesn't offer it, no you can't. iOS devices are like computers, eventually the hardware can't run the software, so it ceases to be offered. My iPod Touch was only offered 1 upgrade, and when I put iOS 7 on my iPhone 4S, it ran so slow I had to get a iPhone 6!
May 21, 2016 | Tablets & eReaders
My airtyme gtx75 torrid does not show my sd cards game & apps files
please tell me what is defualt phone code or security code?
Jun 18, 2012 | AT&T Quickfire Cell Phone
My HTC touch pro has some backlight problem or maybe hardware. When I press the power button the backlight turns on and turns off itself within a split second. and when i leave it to charge. the...
If the resett has not helped to confirm the error to be software related or not it will be good to have it checked on an HTC service centre for a code error. It will then be confirmed if this is a hardware issue.
Get estimate and decide, get warranty if it is within the period.
Sep 29, 2010 | HTC Touch Pro Smartphone
Backlight wont turn on I have a MC218
If you have a very dim display, or no backlight it could be due to a few things. A loose LCD cable could cause the problem, a very basic way to test this would be to apply pressure to various parts of the laptop case and screen bezel, also move the screen and see if a backlight ever powers on. If you are comfortable opening your laptop to check connections then do so. A faulty cable is also a possibility. Sometimes it is a software issue, try turning your display brightness up to max, does the backlight illuminate when in BIOS? If so it is a software problem. Finally it could be a failed LCD inverter, this is a bit of hardware usually separate from the LCD although is sometimes built onto it. These are generally easy and reasonably cheap to replace.<br /> <span style="font-size:12.0pt;font-family:&quot;Times New Roman&quot;,&quot;serif&quot;; mso-fareast-font-family:&quot;Times New Roman&quot;;color:black;mso-fareast-language: EN-GB">Hope this helps,</span><br /> <span style="font-size:12.0pt;font-family:&quot;Times New Roman&quot;,&quot;serif&quot;; mso-fareast-font-family:&quot;Times New Roman&quot;;color:black;mso-fareast-language: EN-GB"><a href="http://www.putercare.com/">www.PuterCare.com</a></span><br />
Aug 27, 2010 | Computers & Internet
How can i get a user manual for my gtx75 phone
Please check the link below:
http://www.wireless.att.com/support_static_files/manuals/ATT_Quickfire_GTX75.pdf
Have a good day!
Dec 14, 2009 | UTStarcom Computers & Internet
For NO apparent reason my iPhone 3GS's backlight has suddenly ceased to work. All other aspects of the phone work perfectly. You can still see all icons on screen but have to tilt it so light reflects the...
If you havent done any of those things, take it in a nd have it repaired. That should be covered under warranty.
If they tell you they wont fix it, check out the followin glink for a low cost Iphone screen repair service
Repair Iphone 3GS Backlight Problem
Dec 01, 2009 | Apple iPhone 3G
Umax powerlook III scanner not working with latest mac system sof
Your OS is not compatible. Period. Either go back to what worked for you or get a new scanner that will work in new environment.
Jun 23, 2017 | Umax PowerLook III Prepress Flatbed...
Cell Phones Logo
Top UTStarcom Cell Phones Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Tafi Nami
Tafi Nami
Are you an UTStarcom Cell Phone Expert? Answer questions, earn points and help others
