Question about Plumbing
Obtaining replacement tecnik water filters - Plumbing
Posted by val_phil on
Francesca Chiorando
    New Friend:
Call APC Distributor on 0161 929 5300 for this spare. They are the manufacturer of the Tecnik water filter TKWFCP05 and are the only suppliers of this part.
Posted on Nov 02, 2011
Paul Beyer
  • 528 Answers
I have a built in Tecnik dish washer about 10 years old it has suddenly stopped working I have changed the fuse any ideas
Any filters on it? There could be a waste filter and water in filter. Waste, if one, should be in or at bottom and water filter would be at the rear of the machine. Normally the flexi hose will have a fine mesh filter filter fitted and that could be blocked by contaminates in the water supply such as limescale. Machine has a pressure flow switch so if blocked the pressure would drop.
Jun 17, 2018 | Tecnik Dishwashers
I have a SE6TIE1, FD 8004 090109 Tecnik dishwasher and when i put my dishwasher on it only makes a little sound right at the beginning and then no sound and does not wash the dishes. I opened up the spray...
The water inlet valve, also called a solenoid fill valve, controls the flow of water into the dishwasher by opening and closing. If the water inlet valve doesn't open at all, water can't flow into the dishwasher.so it can not start the sequence.
Oct 25, 2017 | Tecnik Dishwashers
Where can I obtain a TECNIC model No. TKWF CP05 Water Filter Cartridge - as I have looked on this web site before and found the same questtion under the headings Home - Microwaves, but with no answer I...
Hi Graham
Having same problem - Tecnik phone number just rings and rings, their parts website is down and I just know they will charge a fortune anyway - anyone know of a cheaper alternative as all the filter suppliers I have tried don't stock anything that will fit? It has a 45mm push fit top and is total 253mm long - carbon filled plastic cylinder. Anyway if it ever gets back up try Tecnik:
0161 786 4921. website: http://www.tecnik.net/
Paul
Feb 25, 2011 | Microwave Ovens
Water has stopped going through my Dishwasher!
salt tray does have water in there its supposed to have. its probably the magnetic switch on the mains water line in the dishwasher these can go, it can also be a clogged inline filter this will stop water getting through and is located in between the water line and the unit, removing the the pipe from the back will let you see this. it can also be the main switch on the motherboard as these can go as well and will need replacing but i would check the filter first.
Jan 04, 2018 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Operating manual
Hello
To get a manual for that stove go to this link:
http://www.technika.com.au/
I hope that help...Good luck
Eddie Rentas
Tupper Lake NY
Jul 18, 2008 | Tecnik Cooktops
Machine not spinning.
if its the motor you can hear the belts probably fell off but you may have mistaken the motor noise for the pump so if the belts on check the pump filter
Jun 29, 2008 | Tecnik TKL9260 Front Load Washer
Not cleaning at all - most dishes end up being washed by hand afterwards
Hi there!
You've done the basics, so we'll treat it as a fault due to wear.
When running, do you hear the spray arms rotating - about twice a second?
If the water is actually reaching the dishes, bur the arms are not rotating, you may need replacement spray arms.
If the water is not even reaching the dishes with any force, The circulation pump may be faulty and needs replacement.
Hope this helps you.
Jun 17, 2008 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Plumbing Logo
254 people viewed this question
Top Plumbing Experts
Bill Johnson
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
