SOURCE: No 1384 firewire driver for Panasonic PV-GS300 camcorder
I found the recipe. To get my DV Camcorder to work using 1384 (Firewire) on my computer I did:
1. Get a good cable. If you paid less than $20 for it, you got the wrong one.
2. Ensure that the 1384 (firewire) port is enabled on your computer. Go into the BIOS setup and check to be sure. Mine was OFF!
3. If you get an error with Windows XP not being able to find your hardware, you need to get all the drivers. There are four or five of them along with a configuration file. Miss any one and you are dead. My solution was to reinstall Windows Service Pack 3. This took a long time, but fixed the driver problems.
SOURCE: panasonic pv gs 180 can't import into imovie
Hi, I managed to down load mine by connecting with a firewire and setting the camera to playback mode (not PC), opening imovie, turning the camcorder on and selecting file -' import from camera". a screen came up then I started playback on the camcorder and was able to select import from the screen on the imac.
SOURCE: My windows 7 laptop does not recognize my
You are going to have to check that your firewire is being seen by windows 7 first of all. If not you will need to rectify that.
When you do get it to recognize it, here is a link for an update to the program that came with your camcorder for it to work with Windows Vista but it should also work for Windows 7.
http://www2.panasonic.com/consumer-electronics/support/Cameras-Camcorders/Camcorders/MiniDV-Camcorders/Drivers-Downloads/model.PV-GS39.D#ts
Hope this helps,
SOURCE: I have a Panasonic PV-GS39
This type of camera usually downloads better with a Firewire (DV) connection. Some mini-DV cameras only use the USB connection (if they have one) for stills and can only download video by Firewire. This is because you have to play the tape into the computer, not just copy a file. The way it works on my computer, the camera is controlled by the computer software.
Most PCs have a USB port, but no Firewire port. Macs often have a Firewire port but may not have USB. As most Windows PCs do not come with this interface, you might need to fit an add-on Firewire interface card. This will come with a driver for the card.
Whether this will work with Windows 7, I am not sure. My Mini-DV camera, using a Firewire cable, didn't need any camera driver loaded to the computer, just the movie editor that came with Windows XP.
Testimonial: "Thank you for the quick response. You were very helpful!"
