Ricoh Aficio 1035 Copier Logo
Posted on Jun 30, 2011
Sc403.i replace ic sla6024 on motor but? - Ricoh Aficio 1035 Copier
vincent
Level 1:
New Friend:
  • Contributor 57 Answers
  • Posted on Jul 08, 2011
vincent
Contributor
Level 1:
New Friend:
Answers
57
Questions
0
Helped
31904
Points
76
Look at your blown fuse FU5
• Main motor/drive malfunction
• Transfer belt contact clutch defective
• Transfer belt position sensor
defective
• Harness disconnected
How to fix error code 6 on a roger black treadmill?
1)E00 Safety Key not in the position Re-locate the safety key in the correct position.
2)E01 No signal to Controller from the console
A: Check the Main Controller Wire
B: Replace the PCB Board
3)E02 Motor communication error
A: Check the wire from motor to controller
B: IGBT breakdown, Replace the controller
C: Check the power voltage if 50% lower than rated voltage
D: replace the motor wire or change motor
4)E04 Incline Motor communication error
A: Check the wire from incline motor to controller
B: Replace the incline motor
C: Replace the controller
5)E05 Over current protector
A: Overloading or over resistance,
restart the treadmill
B: Transmission parts seized up, check the parts
C: Replace controller
D: Motor breakdown, change the motor
6)E06 Motor Open Circuit.Connect the Motor link
7)E08 IC Driver Error. Replace the IC driver or change the
IC driver
8)E09 Folding up protect.
A: Do not fold up the running deck when treadmill in is running
B: If the running deck in laying position and show E09, you need to change the controller
9)E10 Motor instantaneous current abnormal
A: Adjust the torsion potentiometer of the Controller to lower
B: Motor Breakdown, change the motor
10)E11 Overvoltage protector Voltage over 270v (for 220v) or 150v (for110v) -- turn off the treadmill and check the power source
11)E13 No signal to console from the controller
B: Change the controller
12)E14 Lower voltage protector Voltage lower than 160v (220v) or 70v (110v) -- turn off the treadmill and check the power source
Can power on
Check the fuses.Blown fuse conditions
FU1 - 6,3A Doors/covers open is displayed.
FU2 - 6,3A Doors/covers open for the finisher is displayed.
FU3 - 4A paper end condition.
FU4 - 6,3A SC 121 is displayed.
FU5 - 6,3A one of SC302 or SC403 or SC405 is displayed.
FU101 - 15A no response.
Fu 102 - 8A no response.
FU103 - 1A normal operation,optional heaters do not work.
If FU or 102 is the problem,verify the main motor and the fusing unit heater lamps and thermofuses.After change the problematic fuse removal the fusing unit and turn ON the copier.
When attempting to load a tape into the AG-DV2000, the cassette door does not open and the display reads F07.
i had the same issue with my ag-dv2000, a fun problem to solve without a service manual. first verify we are dealing with the same issue.first open hopper fully and apply power. you should get an f06 error(failure to close in required time), now close hopper and apply power, you should get a f07 error (failure to open in required time). if this is the case the bad part is the motor drive ic. ic 1 on the motor drive board mounted to bottom of dv mech. it is a 10 pin ic labeled xra6887. i have not located a source yet but you can confirm the chip is bad by replacing it with ic6502 on the same board. if you put the bad chip in place of ic 6502 you will ground power supply and will not have power, leave it out. it controls threading motor, not needed to verify problem. the door should work now. dont put in a tape untill you replace bad chip. if you find the panasonic part number for this part please post it. happy desoldering!
CD player just stopped. Will not respond. Will not open when insertion button is pressed, It just keeps indicating the functions (load, open, etc) but doesn't do anything at all.
The loading motor drive is faulty or the mechanism is jammed. You will have to remove the top cover and check for voltage to the load motor when the open button is pressed, if voltage is present , then motor can be faulty ,jammed. remove , replace or reset.
If there is no voltage press on connectors from the motor drive IC, check voltage here, use a soldering iron to touch up .
if not the drive IC control inputt must receive signal from processor control. If yes then the drive IC can be faulty.
2answers
What is meant by error code SC 403
From the service manual:
SC403: Transfer belt position sensor error
-Definition-
The transfer belt position sensor does not activate even if the transfer belt clutch has rotated once.
- Possible causes -
• Transfer belt position sensor defective
• Poor transfer belt position sensor connection
According to the manual, provided there isn't a major problem with the machine, you can reset the service code by turning off the MAIN POWER switch for a 10-seconds and then turning it back on. This should reset the code provided the problem doesn't reoccur. NOTE: The main power switch is a rocker switch on the front or left side of the machine, not a push-button switch up on the control panel.
Probably not a big help, but hopefully at least a little. I can't offer you much better advice, as I don't work on machines of this age, sorry.
2helpful
2answers
Dvd player does not read dvd
Suggests that the motor regulator IC has problems spinning the disk in a normal way so it will overheat and start to behave in an erratic way - consequentially it may have problems stopping the disk before it ejects.
However, this does not necessarily mean that the IC is bad (far from it), it is just overheating and will usually do so when the spindle motor has oxydized brush contacts - this means that the motor resistance is now higher and that it will not spin at a correct speed with the voltage supplied from the IC.
The electronics will then try to compensate for the speed, but the IC may overheat and start messing up.
Cleaning or replacing the spindle motor might solve the problem, but if the motor can not be replaced because of the unit design and buildup, then this usually calls for the replacement of the entire disk mechanism.
Anyway, this is just one of the possible causes, you might want to try cleaning the laser pickup lens first, but i'm not sure if doing so will make things any better.
regards
Triarcuate
MY 6300.2 TREADMILL IS SHOWING A E3 EROR ON THE DISPLAY WEN START THE MACHINE CYCLE
ERR 3 Troubleshooting Inspect the optic sensor and other components as follows. Optic Sensor 􀁺 Optic sensor wheel – Make sure that the optic sensor wheel rotates securely, without wobbling, between the black optic sensor nubs. Realign and tighten if necessary. If optic sensor wheel teeth are missing or bent, replace the optic sensor wheel. 􀁺 Optic sensor wires – Check wire connections from the optic sensor to the drive board. Check wire continuity . 􀁺 Optic sensor – Turn on unit power. Turn the motor flywheel with your hand. The optic sensor indicator (LED10 on the drive board) should flicker. See MOTOR.08. If it does not light, and all parts above are OK, replace the optic sensor. Other 􀁺 Motor – Does the motor sputter, sometimes running fast, sometimes slow? See MOTOR.04. If the motor tests good, replace the drive board. If the motor tests bad, replace it. 􀁺 Drive board – See above, and inspect for burnt, damaged, or loose components. 􀁺 Main program IC - Press down on the main program IC on the display to ensure a good connection. Replace the IC if necessary
My lg rumor's vibration randomly stops working, so my phone seems like its on silent and i miss alerts because i keep my phone on vibrate. is there any way to fix this?
hello
The problem you have mentioned here can be due to following reasons.
  • The ******** is just a small DC motor which may be malfunctioning. You can replace that motor.
  • The connecting pins which connect the motor to the PCB is not aligned properly so check that also.
  • The motor driver IC is malfunctioning.This IC can be replaced but only by a professional.
Thank you.
2answers
Technics 1200
FYI, there is no motor on these units. The only thing that makes these babies go round is various capacitors, resistors, and IC's... all which play a crucial role in control and maintaining the unit's speed. If you do not have enough torque, then the issue is probably with one of the main IC's (IC101, IC102, or IC201) - however, it could be any of the other circuits as well. A qualified technician should be able to pin point the problem and have it repaired for you. The repair on this isn't that expensive. I'm going to assume 350E is euro? If so, you might as well buy yourself a new Technics 1200 for that amount. If it is not euro, then this type of repair should cost you about $70-120 - including parts and labor. (these are the prices we charge in our NYC shop - for comparison purposes).
3helpful
5answers
LG DR-4810 DVD Displays " PLEASE WAIT"
to open the tray during "please wait", remove casing then loosen front panel (clips either side and underneath). Power up to get "please wait", then press small microswitch in bottom right corner of the DVD player unit. Have you tried resetting the unit (turning on and holding the power button for at least 5-10 seconds)? Have you tried unplugging the unit for a longer period of time (24 hours)? get your firmware upgrade through here(sorry its in german, you might be able to get an english of it through the LG site) - http://www.lgupdate.de.ms/ two cd's- bootloader.iso , update.iso Good luck
Top Ricoh Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
