Tv LED light indication word"LAMP"on the tv front bazel frame is flashing or lighting up.Tv Projection lamp been in the tv like 1 1/2 or 2 years already and daily used tv 4 or 5 hours everyday?Yes,the tv projection lamp must be replaced because the tv projection lamp it life are ending.Tries websites like Partstore.com,Ebay.com to buy a new projection lamp for the replacement.
Hello Required tool: Manual Phillips screwdriver; gloves. 2. STOP! Allow the lamp to cool for at least one (1) hour before 3. On the lamp unit door on the side of the TV, loosen the thumb screw by hand or by using a 5/32" or 4mm Allen wrench, and then 4. Using a manual Phillips screwdriver, loosen the two screws on the Grasp the lamp unit handle and gently pull the lamp unit straight 6. Carefully insert the new lamp unit straight into the TV until it is Note : * Never subject the lamp unit to excessive shock. * Never touch the lamp unit glass or otherwise get it dirty. Doing so may affect the image quality and reduce the service life of the 7. Using a manual Phillips screwdriver, tighten the two lamp unit screws. NOTE : Make sure the lamp unit and screws are installed securely; otherwise, the TV may not turn on 8. Reattach the lamp unit door, making sure to insert the hooks on the left side of the lamp unit door inside the opening in the TV Insert the hooks inside 10. Plug in the power cord and turn on the TV. After the initial warmup period (which may take up to several seconds for full picture brightness), the TV should operate normally. If any of the following conditions exist, turn off the TV, unplug the power cord, and repeat steps 1-9 to ensure that the lamp unit and lamp unit door are
The lamp of your tV has damged and to be replaced.
Optional tool: 5/32" or 4mm Allen wrench
1. Turn off the TV and unplug the power cord
replacing it.
remove the lamp unit door
lamp unit
out of the TV. Set the old lamp unit aside
fully seated
lamp.
Note: Hand-tighten only. Do not use an electric screwdriver
and the lamp life may be shortened
cabinet
the TV cabinet opening
9. Replace the thumb screw and hand-tighten
installed correctly
OK.
Replace lamp
If the display indicates then it is possible that the lamp has failed or that the Power to the lamp is cut off. You will need to check the status of the lamp and also the lamp connectors, the supply from the power.
Check to see if the cooling fan is clogged and so has reset the processor with a error. If so clean the filter to reset.
