Sony Ericsson K610i Cellular Phone Logo
Posted on Jun 30, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am not unable to send text message from my phone, same sim card is working on another phone. plz give me the solution for this thank you
David Lee
Level 3:
  • Master 422 Answers
  • Posted on Jun 30, 2011
David Lee
Master
Level 3:
Answers
422
Questions
0
Helped
64947
Points
1214
In the settings menu, look for messaging server and uncheck the 'packet data' option.
1helpful
2answers
My HTC HD7 will not send or receive media text
Hi, issues like this are related to your Sim card (network),
not your Cell Phone . In most cases, regarding the text messages,
the problem is from the Service Operator. Have you tried the Sim card on another phone? If not,
remove the Sim card, insert it on another phone and try sending a message from another mobile to you number,
or you can do it in vise- versa by inserting another Sim card on your mobile.
If you can't receive text messages even when it's inserted on another handset,
then you will need to call the customer care of your Network Operator and tell
them your problem, they will help you fix it immediately.
You can check the message center number, but I don't think
it's very much important in your case, well, if you wanna try,
just check the text message settings and verify that the message
center number (which is currently in use) is the same number which
is on another phone with the same network (the other Sim should be
of the same network in your area). If it's different, make the changes
and save the settings. Also disable the "Receive Via" or similar settings..
(I can't recollect the exact settings as i don't have the same model with
me, please excuse me for this.).
If the same Sim card doesn't receive text messages using another handset,
don't bother to change the settings or to make any changes with it,
first call the customer care and verify from them, you may make mistakes instead of fixing it.
Hope that helps.
Thanks for using fixya.......
2answers
I had roughly a thousand text messages in my inbox I currently use a HTC desire hd cell phone and today I don't know how but all my messages just disappeared, I didn't do anything differently to maybe even...
Hello
To increase your chances of recovery TRY NOT TO SEND/ADD ANY MORE MESSAGES PHONE NUMBERS once you have realized you deleted a message or number.
If you wish to recover accidentally deleted text messages, contact numbers, call logs or other details from your mobile phones Sim Card then you are going to need to download a good Sim card data recovery program. That is How To Read Deleted Text Messages:
You will require USB sim card reader (any PC/SC Standards or Phoenix Standards based USB Sim Reader) to use the software and successfully recover data (contact numbers and text SMS) from the Sim card of your mobile phone
To use the software you simply connect your USB Card to the computer load up Sim card data recovery and it will allow you to view information including contacts numbers, and deleted SMS text messages along with the date and sending time of the message in simple report format.
Feb 13, 2011 • Cell Phones
Why Nokia N73 Cellular Phone Unable send message?
Hope that helps.
2helpful
Hi there... I am unable to send messages from my samsung monte...tot it was due to sim prob bt when used in otr cel msgs r sent..bt when inserted in samsung monte den hvin an error" unable to send message...
First insert the sim on another mobile and check the Message center number from the Message settings (text message settings), note down the number, now insert the sim onto your handset and go into the message settings then text message and replace the message center number with the one you've noted down, save the changes made and restart your phone, it should work now.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Sep 17, 2010 • Cell Phones
1helpful
Hi im sage i can't receive a txt message but i can send them , plz tell me how to fix this ...
Hi, problems about text messages are related to your Sim card (network), not your Samsung cell phone. In most cases, regarding text messages, the problem is from the Service Operator. Have you tried the Sim card on another phone? If not, remove the sim card, insert it on another phone and try sending a message from another mobile to you number, or you can do it in Vise Versa by inserting another Sim card on your mobile.
If you can't receive text messages even it's inserted on another handset, then you need to call the customer care of your Network Operator and tell them your problem, they will help you fix it immediately.
You can check the message center number, but I don't think it's very much important in your case, well, if you wanna try, just check the text message settings and verify that the message center number (which is currently in use) is the same number which is on another phone with the same network (the other sim should be of the same network in your area). If it's different, make the changes and save the settings. Also disable the "Receive Via" or similar settings.. (I can't recollect the exact settings as i don't have the same model with me, please excuse me for this.).
If the same Sim card doesn't receive text messages using another handset, don't bother to change the settings or to make any changes with it, first call the customer care and verify from them, you may make mistakes instead of fixing it.
I hope it helps.
2helpful
3answers
I HAVE NOKIA 5530 XM. IT CANNOTSEND TEXT MESSAGES. WHEN I PUT MY SIM IN ANOTHER PHONE , IT SENDS MESSAGES, MEANS THE SIM IS FINE, AND WHEN I PUT ANY OTHER SIM IN MY NOKIA 5530 IT SENDS MESSAGES, MEANS THE...
nice noon...you need go to cellphone repair shop anf try to reprogram or master reset your phone,,i think the problem of your phone is software..good luck....
2answers
NK1100 can't send text message.
Sorry to say these but i hope the time has come say goodbye to your master piece phone..i guess many such problems has been reported.. but i can't find any solution for the issue..
Cheers!!
Jul 28, 2009 • Nokia 1100
Can't text with this cingular razr with a tmobile sim card
Your service center number may be wrong in the phone. Call T-Mobile and ask for the service center number. You should be able to find it in your text messaghing settings. If it is rong (since it varies between carriers) it will stop text messages from going out.
You may also want to try your sim in a tmobbile phone and see if you can send text. Might be a problem on the network, not just with your cingular phone.
Top Sony Ericsson Cell Phones Experts
Sean Wright
Sean Wright
Kolbrun...
ZJ Limited
ZJ Limited
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
