SOURCE: Samsung LaserJet prints completely black pages
We had the same problem with our SCX but we replaced the Part #: SCX-4521D3 toner/drum and it worked fine after that. We replaced the starter cartridge with a 3000 print capacity cartridge.
SOURCE: problem scanning with samsung scx 4521f
My connection is via a parallel to parallel cable, and I am also having a similar problem. I'm reading that usb to usb cable is the only way it will properly function. good luck with it!
SOURCE: SCX 4521F scanner driver will not configure. Have
The problem is the firewall of your computer because its blocking the scanner to work better. Check the firewall of your computer from it is control panel if its on. If it is on, click the exception tab then check the network scanner tool and scan to pc box. Just put acheck on all scan or scanner word.
SOURCE: I have a Samsung Scx-4521F scanner copier.
may be ADF lence is very dirty so your scnning problem.Clean the lence throughly glass cleaner then solve your problem.
