I put in a couple of games and they didnt work but they were clean and i put achohol on the disc and it started to work for a little bit now my games dont work
The Playstation 3 is a wonderful video game console, however, with heavy usage, the laser does eventually burn out. The first signs of the laser starting to burn out is that your game will start freezing during game play. Eventually the game will stop reading altogether (even though movies sometimes still work). Eventually movies will stop working and the whole laser will eventually die.
The following website sells PS3 lasers and also performs repairs:
It wont read your discs simple because the lens could hardly read them because it is dirty and probably needs cleaning. Try running a disc cleaner and let it spin for like 30 seconds. Then try playing those discs again. If this does not work, then you might need to clean the lens manually by disassembling the wii, taking out the casing and cleaning the lens with a swab damped in an alcohol. Just gently wipe the swab on the lens surface in a circular manner and let it dry. Then put everything back and try playing those discs again.
By the way, this video might give you an idea how to disassemble the wii.
if you are talking about a disc try using a little bit of deoderant or after shave on a soft cloth and rub in a small circular motion starting at one side and working your way around (see video). dont use too much but if you just use a little bit and rub it properly it should work. if that doesnt work then the disc is scratched at a certain part and cannot be fixed. my method is proven to work if done right. i have had games cleaned by video store cleaners and i have even bought special disc cleaning kits and that and nothing could fix my discs but when i did this method i have had even the dirtiest scratched discs work again. this method works 90% of the time but like i said if this wont fix it nothing will. hope this helps.
take the Ps2 gaming console to nearest Sony service center the problem is with lens it sometimes run quiet well but sometimes got hang you can do one little thing & try it take any of the Ps2 games which are getting freeze while playing take Colgate toothpaste the regular one take a little bit of it & apply on the game disc rub it on the disc & then clean & wipe out with a clean smooth cloth & clean properly after cleaning the disc will look good neat in condition but please make sure no particle is left after cleaning & now play the disc on Ps2 & see if it still get freeze then their is a problem with console better check it at nearest Sony service center for trouble free working
put a little bit of water on it or blow on it i am not sure if it works but ive tried putting a little bit of water on just a little spred it around the disc part it worked when i done that
wow thats a big game ..i dont think you have a problem with your machine.. it sounds like a game glitch that didnt get worked out you know game laggg .
