SOURCE: Printing of incoming faxes
I have the same problem on my hp all-in-one. it looks like a staple went through the copier and it shows on incoming faxes as well...
SOURCE: Fax does not print a confirmation page.
Use Function 8 not 6 and use set to lock it in. Lawrence
SOURCE: DOES NOT PRINT INCOMING FAX- PAPER COMES OUT BLANK
Have you tried a new toner cartridge?
Did you pull the plastic tape on the cartridge?
SOURCE: Panasonic kx-f1100 fax prints and sends 1 page on 2 pgs- 2big!
I found the solution to my problem: Press Menu, Pound Key (#), 35 to set copy size, 36 to set fax size, press Start/Set, then use up/down arrows on right side of the machine to select 92%, 86%, 72%, or Off. Press Start/Set to select desired setting.
Press Menu to exit!
SOURCE: when faxing a 401 error is reported
error 401 means that your number is not programed in the machine you are trying to , so it blocks it
