Question about Cameras
How do I turn on the Rear Command Dial in my Nikon D80 Digital Camera?
Posted by fotobug1503 on
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Cameras Master
  • 102,366 Answers
That depends on what you want the command dial to do. If you're in either the Manual (M) or Shutter Priority (S) modes, the command dial will change the shutter speed. If you're in the Program (P) mode, the command dial will shift the program exposure. If you're in any other exposure mode, the command dial does nothing.
If you hold down the metering mode button, the command dial will change the exposure metering mode.
If you hold down the exposure compensation button, the command dial will change the amount of the exposure compensation.
If you hold down the release mode button, the command dial will change the release mode.
If you hold down the AF button, the command dial will change the autofocus mode.
If you hold down the QUAL button, the command dial will change the image storage mode.
If you hold down the ISO button, the command dial will change the ISO.
If you hold down the WB button, the command dial will change the white balance setting.
If you're looking at the menus, the command dial will navigate the menu.
If you're reviewing pictures, the command dial will move to the previous or next picture.
Hope this helps. If you still have problems or other questions about this, please don't hesitate to reply to this post.
Posted on Jun 29, 2011
How do I fix my Nikon D80? It is flashing F-- and will not take pictures.
What lens do you have on the camera? The F-- indicates that the camera is unable to communicate with the lens. If the lens has the electronics to communicate with the camera, try cleaning the contacts on the back of the lens and on the camera body. If the lens is a manual lens, set the camera to the Manual exposure mode (turn the mode dial to "M").
Jun 14, 2014 | Nikon D80 Digital Camera with 18-135mm...
Vivitar 84mm 1.4 aspherical on Nikon D80
If you mean the 85mm, it's not an autofocus lens. Nor does it have the electronics to communicate with the camera. You need to set the camera to manual exposure mode (turn the mode dial to M) and set the exposure manually. Set the shutter speed by turning the command dial on the back of the camera and the aperture by turning the aperture ring on the lens.
Again, this is a manual lens. No auto-anything. But it's a nice fast lens, with shallow depth of field when you want it.
Jan 10, 2013 | Cameras
How do I get a nikon d80 to use a manual lens
If you mean a manual-focus lens, just focus the lens using the focus ring on it.
If you mean a non-electronic lens, then you need to set the camera to Manual exposure mode. Control the shutter speed by turning the command dial. Control the aperture by turning the aperture ring on the lens. You will get no metering assistance from the camera: you can use another light meter (this includes using a different lens on your camera just to get an exposure reading) or just take pictures and look at the results on the LCD.
Sep 23, 2010 | Nikon D80 Digital Camera
How do you turn off automatic flash manually on Nikon d80?
Assuming you're in one of the point&shoot modes (any mode other than the PSAM modes), press and hold the flash button on the front of the camera and turn the main command dial on the back to cycle through the available flash modes. To turn flash off, select the lightning bolt in a circle with a slash through it.
In the PSAM modes the flash will not pop up on its own.
Aug 22, 2010 | Nikon D80 Digital Camera with 18-135mm...
I got a remote for my D80 how do i get it to work?
Set the Release mode on the camera to one of the remote modes by holding down the release mode button on the right of the camera (the one with the remote and the clock-like self-timer icons) and turning the command dial on the back of the camera. The two choices are Quick-response, where the camera takes a picture when you press the button on the remote, and Delayed-response, where the camera waits two seconds while you hide the remote behind your back before taking a picture.
Look in the camera manual under "Choosing a Shooting Mode" and "Using a Remote Control". They are on pages 36 and 38 of my copy of the D80 manual, yours may differ.
Jan 20, 2010 | Nikon D80 Digital Camera with 18-135mm...
My D80 nikon camera was not working specially on
Check the following:
- Make sure your lens is screwed on correctly. Try to remove it and put it on again.
- Make sure the dial is squarely pointed to Auto
- Make sure the Auto-Focus switch in front of the camera is turned to A (not to M)
Dec 29, 2009 | Nikon D80 Digital Camera with 18-135mm...
Deh778 question about Rgb histogram not turning off.
If you haven't solved the histogram issue by pressing the multi selector up or down or rotating the sub-command dial to choose photo information display then OK.  The D80 is a very reliable "prosumer" camera meaning it's more than a consumer model offering better quality and features commonly found on professional camera models, if you are a budding photographer and desire more control over the images you take and the options to take creative images working with the amount of light, the shutter speed and may other aspects the pros do then it's worth it, if those features are not important then having all the control might be a problem if that isn't what you are after.  Early digital cameras were pretty poor quality and could never compare to film cameras, even the early model D70 had some issues with battery life.  Take the time to learn about this camera and you will be very happy.  I know several professional photographers who use the D80 and find Nikon stands behind the camera.  If you have any other specific problems or issues let me know, I'd be glad to go over them.
randy320sgi
Dec 13, 2008 | Nikon D80 Digital Camera with 18-135mm...
How can I change the exposures, or f-stops on the Nikon N75 35mm camera?
That depends on the exposure mode. In the point&shoot modes the camera sets the exposure.
In P you can turn the command dial to change the exposure.
In S you turn the command dial to set the shutter speed, the camera changes the aperture to suit.
In A you turn the command dial to set the aperture, the camera changes the shutter speed to suit.
In M you turn the command dial to set the shutter speed, you hold down the aperture button and turn the command dial to set the aperture.
If you don't have a manual, get one from http://www.butkus.org/chinon/nikon.htm
Oct 16, 2008 | Nikon Cameras
How do I activate the Nikon ML-L3 remote for the nikon D80 camera?
Set the camera's release mode to one of the remote modes by pressing the release mode button next to the top panel LCD and turning the command dial. The Quick-response mode snaps a picture when you press the button on the remote. The Delayed-remote mode gives you a chance to hide the remote behind your back.
Aug 01, 2008 | Nikon Cameras
NIKON D80
check that your flash is not up. Or if you have an external flash, turn it off.
Jun 16, 2008 | Nikon D80 Digital Camera with 18-135mm...
Cameras Logo
Top Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
