Nokia 3230 Cellular Phone Logo
Anonymous Posted on Jun 29, 2011
My sim is not active to gprs - Nokia 3230 Cellular Phone
Anonymous
Level 3:
  • Master 352 Answers
  • Posted on Jun 29, 2011
Anonymous
Master
Level 3:
Answers
352
Questions
0
Helped
83998
Points
1329
GPRS setting depend on the network you are using. In Nigeria, MTN GPRS setting is given below For your Nokia phone, the basic setttings are these; GPRS/WAP Settings Account Name = MTN GPRS or any other name IP Address = 10.199.212.2 Port = 9201 (for WAP) or 8080 (for HTML ) Username = web Password = web Access Point Name (APN) = web.gprs.mtnnigeria.net
So, please contact your service provider to give you your GPRS Setting.
Regards
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 16, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
226
Points
Manuel configuration of all vodafone
7helpful
How to set up gprs for nokia c2-00
Hello there,
Have a blessed day. My name is adieh.
If you are using a new sim just go to MENU>sim beside Web then sim settings from there you can see the MMS/GPRS/3G,just click Activate. After you clicked activate there will be a "Warning" to be prompted just click "OK" then you go to phone model. Type N70 but do not worry because it has the same settings with the Nokia c2-00. You will be receiving the configurations you have to do is to save it and finally your gprs is activated. Another option is that you can call the customer service and ask him on how to activate GPRS and he will ask some questions from you.
Hope it helps.
Thank you for using fixya.
How to access internet in samsung sgh-d900 phones please explain the steps to connect to internet
TO ACCESS INTERNET ON YOUR MOBILE YOU SHOULD HAVE
  1. GPRS ENABLED DEVICES.
  2. WORKING GPRS NETWORK.
FIRST OF OF ALL YOU HAVE TO CALL YOUR SERVICE PROVIDER TO ACTIVATE GPRS ON YOUR SIM CARD (YOUR NAME SUGGEST THAT YOU ARE FROM INDIA SO IF YOU HAVE AIRTEL SIM THEN DIAL *567# OR HAVE TATA DOCOMO SIM THEN DIAL *141# TO ACTIVATE GPRS BY YOURSELF.)
AFTER GPRS ACTIVATION AGAIN CALL CUSTOMER CARE AND ASK THEM TO SEND SETTING ON YOUR DEVICE(IN AIRTEL SEND "MO" TO 543210 FOR TATA DOCOMO SEND "INTERNET" TO 52270)
AFTER RECEIVING SETTING SET THEM AS DEFAULT SETTING.
NOW OPEN YOUR BROWSER AND ENJOY SURFING AND DOWNLOADING.
THANK FOR USING FIXYA
1helpful
2answers
How to open the gprs on nokia 5230
FOR GPRS YOU HAVE TO ASK YOU SERVICE PROVIDER.
JUST CALL ON CUSTOMER CARE AND ASK THEM TO ACTIVATE GPRS ON YOUR SIM CARD.
USUALLY NOW A DAY SIM CARD COMES WITH PRE ACTIVATED GPRS (0 RENTAL PLAN).
IF YOU HAVE ACTIVATED GPRS THEN AGAIN CALL CUSTOMER CARE FOR GPRS SETTINGS.
SETTING WILL DELIVERED TO VIA SMS. SAVE THEM AND SET THEM AS DEFAULT SETTING.
NOW OPEN YOUR DEFAULT BROWSER AND ENJOY.
ALWAYS USE FIXYA TO FIX YOUR PROBLEM.
How to activate the GPRS when i'm using Talk N' Text Sim
GPRS is a service which must be activated through your cellular service provider. GPRS (Data Service) may - or may not - be able to be added to your account. You'll have to contact your cellular provider to determine if you'll need another SIM card if you plan to use Data service.
1helpful
How to open the GPRS of chinaphone
creating data accounts:
Steps:
1. Open Services Menu.
2. Open Data Account.
3. Open GPRS.
4. Create/Edit Data Account and enter the following values:
For Globe MMS Data Account:
Account Name: GlobeMMS
APN: mms.globe.com.ph
User Name: leave it blank
Password: leave it blank
Auth. Type: Normal
For Globe GPRS Data Account:
Account Name: GlobeGPRS
APN: http://www.globe.com.ph
Auth. Type: Normal
For Smart MMS Data Account:
Account Name: SmartMMS
APN: mms
Auth. Type: Normal
For Smart GPRS Data Account:
Account Name: SmartGPRS
APN: smart1
Auth. Type: Normal
5. Save the Data Account.
Configuring WAP/GPRS/Internet Services Using the Data Accounts Created
2. Open WAP.
3. Open Settings.
4. Open Edit Profile.
5. Create/Edit a Profile and enter the following values:
For Globe GPRS Profile:
Rename Profile: myGlobe GPRS
Homepage: http://www.globe.com.ph/globe.asp
Data Account: GlobeGPRS (this data account is the one you have created)
Connection Type: HTTP
Proxy Address: 203.177.042.214
Proxy Port: 8080
Username: leave it blank
For Smart GPRS Profile:
Rename Profile: SmartGPRS
Homepage: http://wap.smart.com.ph
Data Account: SmartGPRS (this data account is the one you have created)
Proxy Address: 010.102.061.046
Proxy Port: 8080
6. Save the Profile.
7. Activate the Profile.
8. WAP/GPRS/Internet services now ready to use. In case you encounter errors, double check the Data Account and Profile created. In some cases you need to restart the phone.
Configuring MMS Using the Data Accounts Created
1. Open Messages.
2. Open MMS.
3. Open Message Settings.
4. Open Server Profile.
For Globe MMS Profile:
Rename Profile: GlobeMMS
Homepage: http://192.40.100.22:10021/mmsc
Data Account: GlobeMMS (this data account is the one you have created)
Proxy Address: 192.040.100.020
Proxy Port: 8080
For Smart MMS Profile:
Rename Profile: SmartMMS
Homepage: http://10.102.61.238:8002
Data Account: SmartMMS (this data account is the one you have created)
Proxy Port: 8080
8. MMS services now ready to use. In case you encounter errors, double check the Data Account and Profile created. In some cases you need to restart the phone.
This configuration is working perfectly using ZT321, Baizhao 8928 and IPhone Clone A380 and probably will work using other China Phones.
If your SIM card is previously activated using other phones specially those phones supported by Globe and Smart, no need to activate your SIM. This is also valid for postpaid users since SIM cards are pre-activated for MMS, GPRS and other services.
But if your SIM is not yet activated or never been used for MMS and GPRS, you need to activate your SIM before you can use MMS and GPRS services.
For Smart SIM, you can use your China Phones to activate MMS and GPRS by simply sending/texting MMS ON / GPRS ON to 333 (I don?t know if this number is still valid). No need to download the configuration for Smart. Just use the configuration I?ve given.
For Globe SIM, this is a little bit harder and need some workaround. I tried to call Globe Customer Service but they cannot activate your SIM manually on their system and the only way to activate it is by downloading the configuration thru text or by asking them to send the configuration. But since China Phones are not yet supported by any Service Provider, what you can do is to active MMS and GPRS using another phone. Monitor until your SIM is activated then transfer your SIM in your China Phone and enjoy surfing and sending MMS.
In another forum, they said you can try using configuration for SE p900. I?ve never tried this but if this really works, well and good for China Phone fanatics.
6helpful
3answers
How to open the GPRS?
Press and hold down the 0 digit key.
1helpful
2answers
SIM LOCK
hi i locked my sim card, i went onto 02 website and went onto PUK code. it asks you to put your phone number in then comes up with the code. i put the code in and it it worked
3answers
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
