Question about HP Deskjet 2360 InkJet Printer
SOURCE: hp deskjet 6980 blinking lights
ok so for this situation you have to do a cold reset, and by this you have to go ahead while the printer is still power on, disconnect the power cord in back of the printer, and wait for about two minutes. power on the printer if printer still has the blinking lights then go to step 2.
step 2-after this check the printer if light are still blinking, then your going to remove all printheads, remove paper, and then unplug printer power cord from printer and also from the wall outlet, wait for 20 seconds, then power on the printer, wait for light to flash then install the printheads, put paper, and press the resume button.
*** always connect your printer to a wall outlet never to a power strip, the power strip robs some of the power from the printer***
and this should fix the problem if it doesnt then the carriage might me malfunctioning . hp recently did a recall on some printer with the 6940 and some of the 6980, that the carriage broken.
Hope this help!
Posted on Mar 06, 2008
SOURCE: HP deskjet F4140 Error light on & I can"t print
please reset your printer. turn off your printer, leave it for 30 sec and turn it on again....
If you still have problem try to re install the catridges again, follow below instruction
http://etech.maiila.com/hp-deskjet-f4140-all-in-one-printer-catridges-installation
Good Luck
Posted on Nov 01, 2008
SOURCE: HP deskjet F2180 not scanning.
I would suggest that you remove all HP software that came with the printer through Add/Remove programs in Control panel. After that is finished, you can download the latest drivers by following the instructions below.
To download the drivers you can go here. When the page opens you will need to choose your operating system. Then, from the Drivers section I would choose the full feature driver. Once you click that, you will see a Install Now button that will allow you to immediately install the software and/or a Download Only button that will allow you to download the file for later installation.
Either option will have a link below them that says View Directions which can be used to get step by step instructions for installation of the drivers.
Hope this helps. Please remember to rate this information.
Thanks
Posted on Jan 03, 2009
SOURCE: HP D4160 Everything OK, except blinking orange arrow; cant print!
reset printer.
Posted on Jun 01, 2009
SOURCE: Have an HP Deskjet F2180
try connect your printer to your computer,
then manually go to 'my computer',
then double click on the printer,
then choose scan.
Posted on Aug 03, 2009
Aug 23, 2011 | HP Deskjet D4260 Printer
Mar 25, 2011 | HP Deskjet 6980 InkJet Printer
Mar 25, 2011 | HP Deskjet 6980 InkJet Photo Printer
Jun 15, 2009 | HP Deskjet F2180 All-In-One InkJet Printer
Jun 09, 2009 | HP DeskJet 5550 InkJet Printer
Mar 02, 2009 | HP Deskjet 6980 InkJet Photo Printer
Jan 23, 2009 | HP Deskjet F2180 All-In-One InkJet Printer
Oct 06, 2008 | HP DeskJet 1280 InkJet Printer
Aug 21, 2013 | HP Deskjet 2360 InkJet Printer
441 people viewed this question
