Question about Whirlpool ACQ122XK Air Conditioner
The filter light keeps blinking. the filter isn't dirty. the filter is in the front and slides out either side. we keep it clean. so.. how do i get it to quit blinking? is there some regular maintenance i need to do to it?
Posted by Polly McKinney on
Rich Landrum
    Brigadier General:
  • 4,736 Answers
Pam, be sure tat the filter is properly installed. Whenever you remove the filter for cleaning, be sure to turn the unit OFF, before removing it. And back ON after it is cleaned and reinstalled.
For the blinking problem. Turn the Master ON/OFF Switch to OFF and unplug the unit for 15 minutes. Once the time has elapsed, plug the unit back in and turn the Master ON/OFF Switch to ON. Hopefully, during that 15 minute timeout, the unit's electronics reset themselves and reverted back to the original factory settings. If so, the filter light should have stopped blinking, if the filter is installed properly.
I hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Posted on Jun 29, 2011
Location of fuses for cabrio dryer # wed6200swl
pull out the dryer,remove the vent line and remove the back wall,you'll see the metal duct that the lint filter slides down into,look to the bottom right of the duct,you'll see a white piece with two wires on it,this is the thermal fuse part number 3392519,fuses are usually on the blower wheel housing and on the heater housing,if the lint filter is on top then the fuses are in the back of dryer,if the lint filter is inside then the fuses are up front.if the fuse is bad you have to clean out the dryer and blow out the vent line,remove the duct that the lint filter slides into,your filter is on top so remove the two screws that are in front of the lint filter onthe top panel,then if the vent line is long you can blow it out with a leaf blower,first go outside and make sure there isn't any covers or anything blocking the vent,if there is a cover remove it,the lint will keep getting stuck in it and you'll have problems.so check the thermal fuse and if that's good check the thermostats and high limit on the heater box,also make sure you have 240 volts going to the dryer,check the door switch,also make sure the belt isn't broke,there's a switch that kills the power if the belt is broke.hope this helps if not you could have a computer board issue
Sep 07, 2012 | Whirlpool WED6200S Electric Dryer
My Mom has a Fedders Window Air Conditioner Model # A7T12F2A Serial # CP961286 075E
Switch off, press reset and switch back on. Keep reset pressed for 10 secs. Check the bit behind the filter is also clean and check the drain isn't clogged.
May 16, 2012 | Fedders Heating & Cooling
Thumble dryer not working
Filter at bottom of machine needs pulling out and cleaned on a regular basis. This is a common fault and the lights is telling you to clean the filter. It is a large filter that unclips at the bottom front of machine. Remove two amall screws from the front of the filter located left and right and gently remove the front plate. Once removed you will see a metal filter clogged with clothing debris. Clean with cotton buds and a damp cloth till clean. replace all parts and you should have it working once again with a good heat source as well. Every 2-3 months is sufficient to keep it cleaned. Hope this helps.
Dec 21, 2011 | Dryers
I HAVE THE BHD-301-D COMFORT AIRE DEHUMIDIFIER AND THE LIGHT KEEPS BLINKING AND IT WILL NOT RUN I DO NOT KNOW WERE THE FILTER IS TO SEE IF IT NEEDS CLEAN CAN YOU HELP THANKS
The filter is located behind the front louvers. It can be accessed by removing the water collection bucket and looking up into the bucket holder, just behind the louvers. You should see a plastic pull tab handle, which is the filter frame. If you have never removed the filter for cleaning, it may have a piece of plastic tap, which was used for shipping. you will need to remove the tape and discard it, before pulling straight won the filter frame.
The filter can be cleaned by vacuuming it or if it's really dirty, washing it it in warm water and mild dish washing liquid. Rinse thoroughly and shake off any excess water and dry the filter completely before reinstalling it. Never operate the unit with out the air intake filter in place.
Hope I was able to help you and thanks for choosing FixYa..
Sep 05, 2011 | Comfort-Aire BHD-301 Dehumidifier
Brada ypm-06c air conditioner not cooling the room down no matter what i do! keep getting E3 code. is it normal for the lcd lights to keep blinking and blinking! SO annoying when in the bedroom at...
You need to clean the filters and coils on this unit so the error code will go away and the unit will work like it should. If it can't get clean air across the coils it will freeze up and not circulate any air. Most common issues are dirty filters and dirty coils that prevent air flow. Is the fan working to blow air? this code could also mean the fan is not working. Check on these and let me know.
Aug 05, 2011 | Heating & Cooling
My olympia mastertype 3 typewriter,does not print the key I am typing. Please give me an idea of what to check
On the L. side of the keyboard is the pitch slide switch be sure that it isn't in PS, if it isn't S'slide it up and down a few times they do get dirty.
DickyO
Jul 25, 2011 | Olympia Mastertype 3 Typewriter
I have an LG DLE2532W and the check filter light keeps blinking even though it is clean and the dryer won't work what could be wrong?
There is a thermostat or safety somewhere on the dryer where the filter is and it probably is dirty or bad.
Mar 13, 2011 | Dryers
I have a wd52525 the status light keeps blinking
There are 3 different LEDs on the front of this televison. The TIMER will blink green. The STATUS will blink orange and the LAMP will flash red or orange depending on if there is a failure or if the lamp timer is showing over 5000 hours.
If I answer your question directly and the status is blinking a steady orange light, then you have left the side filter cover or the front lamp cover off or they are loose.
Also holding the menu and device buttons together until the timer light blinks will reveal a code that will help in diagnosing your problem. Goodluck.
Jul 04, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Green blinking light CH
That is no problem .CH is for that side door is open .just close it or check side door sensor it is dirty clean it .MIAN AKHLAQ
Dec 24, 2008 | Sharp AL 1631 Copier
Whirlpool ACQ122XK Air Conditioner Logo
349 people viewed this question
Top Whirlpool Heating & Cooling Experts
Bill Long
Dennis Boxerman
Pete Norton
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
