Question about DISH Network ViP622 DVR DTV Receiver / 180-Hours Video Recorder
Can you record a program and watch live TV at the same time?
Posted by vballtx on
Ray Calo
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 358 Answers
If you have a dual receiver, you can record to TV 2 and watch any program on TV 1. If you have 2 recordings taking place at the same time, you can only watch what is being recorded.
With a dual receiver, you can place the receiver in single mode and watch a different program even if 2 recording are taking place. In single mode both TV 1 and TV 2 will be watching the same program.
A solo DVR you can record to tuner 2 and watch what you want on TV 1. With the VIP 622 receiver, you have the Record Plus option, you can have all recording go to TV 2. If 2 recordings take place, then TV 1 and TV 2 are used.
Posted on Jun 29, 2011
Why cant I change channels when recrding 2 progs?
Hello Anonymous,
You did not specify if you are using a DVR capable cable/satellite box, which I what I presume is the case.That DVR has two tuners in it - each tuner allowing you to watch and/or record two programs at one time and in any combination.If both of those tuners are used for recording then you cannot watch another "live" stream as there no available tuners to tune and display (or stream to the DVR hard drive for recording). You can only switch between the two recording programs.
As a side note, if your TV has a built-in tuner, you can split the cable and have one going to the DVR and the second run going to the TV set. You can then use the TV's built in tuner and watch what anything it can get. It won't get scrambled digital cable but will get analog and Clear QAM channels.
Feb 15, 2015 | Televison & Video
TV switch to live tive when wtaching recorded program
Hi there anil! My name is Kimberly and I form part of the Social Media Department with DISH, It is my pleasure to assist you. When watching an already recorded event and having a timer set up to record it should not interrupt your viewing of that DVR event. When this happened, did you get an error message on the screen? And has this happened again? Please reach me at: [email protected] with the details.
Kimberly. Escobar
Social Media Representative
DISH L.L.C
Dec 14, 2013 | DISH Network ViP 922
Dish changing channel to new recording while watching *pre-recorded* program
rjvdw,
Try unplugging the receiver for 10 seconds then plugging it back in, and see if the problem is resolved. The receiver should only switch if you are watching live TV instead of a recording.
If the problem persists, and you are for sure not on Live TV, the receiver may need to be replaced. If it continues you can send me an email at [email protected], and I can assist you further!
Tommy Faust
DISH Internet Response Team
Jan 23, 2012 | DISH Network 54 1 Ir Vip 622 722 Dvr...
Can i watch tv on one tv while another person watch a recorded show at the same time?
Hey russ fenton,
On the 625 receiver; the Dual mode allows you to record in one room and watch live TV in the other or watch live in one room and a recording in the other.
Tommy Faust
DISH Network
Oct 24, 2011 | DISH Network DVR-625 DTV Receiver /...
While watching a recording of a program that is also on at the same time, the dvr jumps ahead to the LIUVE mode. How do we stop it from jumping ahead?
Check your recording to see what the duration of the recording is. If the whole event is not being recording, that could explain why it is going to live mode. While recording an event, you can watch the recording. Please send me an email with a little more information: what method you are using to record, TV 1 or TV 2, and if this is happening all the time or just began. Here is my email address: [email protected] Thanks.
Jul 07, 2011 | DISH Network ViP722 DTV Receiver /...
Cant record two programmes at once
Well no matter the DVR, you should be able to record 2 programs at once...but you CANNOT watch a 3rd live while they are recording...also, if your DVR is hooked up to more than one tv and someone is watching something else in the other room, it will not record 2 at once, either. You can watch RECORDED programming while 2 others are recording, but not live tv.
You might want to check how many "inputs" your DVR has...most have 2 which allows the double recording...if you have an older DVR maybe you only can do one at a time. On my DISH box, they call these "TV1" and "TV2".
Hope this helps.
May 14, 2011 | Televison & Video
Problem with DISH DVR 625
You can accomplish this by either going to the specific TV and selecting the record option at the time the program is about to come on or you can press menu-8-5 and change the record preferences. You can either set the DVR to record programs to the TV2 location by default or TV1 by enabling the record plus feature. In dual mode without record plus enabled all programs you select to record default to the tuner you are viewing e,g, if watching tv1 and selecting to record a program in the future it will record to the tv1 location.In single mode all recordings default to tv2 so you can continue to watch live tv from tv1. I hope this answers your question and thanks for using Fix Ya. Let me know if I can further assist you.
Dec 14, 2008 | DISH Network DVR-625 DTV Receiver /...
Record
While we have the DishTV receiver/DVR, I suspect they are similar in principle.
You can't really do as you describe unless the unit has two individual tuners; some do, some don't. You'd need to check your manual to ldetermine that.
What you can do on all with the DVR function is watch a pre-recorded program since that comes from the hard drive, not the tuner.
This allows you to record one live and watch previously recorded material.
Aug 17, 2008 | Hughes HR10-250 DirecTV / TiVo 200-Hours...
Tivo and direct tv
No, unfortunately there is not. That tivo only has 1 tuner, so you can only record or watch 1 live program. You can however watch a pre-recorded program while recording a live program. If you have directv, you can step up and get their hr20 dvr. It's not a tivo by any means, but it has 2 tuners so you can record 2 things at once and watch a pre-recorded show. It takes a little while to get used to the interface, but once you get the hang of it, it's pretty straightforward.
You can also get an older DVR w/ tivo (hr10) however, it will not get ANY of the new MPEG4 High Def channels that are out there.
If you have an hdtv, then you really should grab an hr20, give directv customer retention a call and ask what they can do for you. You'll need a new slimline dish and they'll come out install it and everything you need for watching off the new satellites and enjoying the new mpeg4 hd channels (the old hd channels are in mpeg2).
Good luck.
Dec 12, 2007 | Tivo Series 2 80-Hours Video Recorder
Open Questions:
Dish 722 not acquiring signal on boot up. must disconnect antenna cable and reconnet then works fine. Dish Tech support is useless and my contract is up in 1 month, so I am considering canceling. Any This problem began about 6 months ago. Nothing unusual happened that I am aware of. When the system is first booted, it will stay on the acquiring satellite screen with no progress and ultimately fail. If I disconnect the antenna (LNB) cable and reconnect then it immediately shows progress and acquires the satellites and works fine until it is shut off and restarted again. Dish Tech support is useless, no they are LESS then useless. I have tried replacing the antenna dish and lnb, running new cable from antenna to receiver, replaced the splitter switch (for 1 and 2) all with no success, so I have concluded this issue must be with the 722 receiver itself. As I mentioned I have made 3 attempts to get help from dish with no success ("maybe there are clouds in the way every time you boot the receiver and they happen to disappear just when you disconnect and reconnect the cable" <<< No I am not kidding). I thought it might be a grounding issue so I ran a separate ground directly to the antenna dish with no success. SInce the 1000.2 antenna does not require a seperate switch, I have tried connecting the LNB cable to each of the 4 inputs on the LNB with the same result on each. We live in Florida so we shut the receiver off when we are not home to reduce the danger of lightning damage, consequently this problem becomes an irritant on a daily basis. Any ideas? My contract with dish ends in 1 month so if I cannot fix this, I am most likely going to switch to cable or directtv. Except for this problem the unit works properly as does the dvr.
Feb 28, 2017 | DISH Network ViP622 DVR DTV Receiver /...
DISH Network ViP622 DVR  DTV Receiver / 180-Hours Video Recorder Logo
232 people viewed this question
Top DISH Network Televison & Video Experts
matt martin
matt martin
Sheldon Dedek
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
