Question about Ranger RCI-6900F-25 CB Radio
Which is the proper fuse for the Ranger RCI 6900f High Power?
Posted by josephhayse on
wcrave
    New Friend:
    Problem Solver:
  • 19 Answers
7 amp is sufficient.
....Don at NTCB, Inc.
Posted on Jun 29, 2011
My rci ranger wont transmit but it receives great what is the problem
it could be several things......the rf final,bad mic,cold solder joint on the circuit board just to name a few.my suggestion is to find a good local cb shop,if no local shop find one along the interstate hwy most of the time they are located around or near some of the larger truck stops. tell the tech there what the problem is and go from there. good luck !!
Apr 04, 2013 | Ranger Communications RCI-6900F-25 CB...
Ranger rci 2950 will not transmit
have you tried it on all bands? still won't transmit?take it to a tech so they can fix it properly.
Sep 16, 2012 | Ranger Communications RCI-6900F-25 CB...
Ranger rci 2950 no am hash and sometimes loses lsb hash and wobbles on recieve and transmit
hmmm my money is on a cold or several cold solder points,,
start checking the legs on the PLL first...
Oct 03, 2011 | Ranger Communications RCI-6900F-25 CB...
Ranger RCI-63FFC4 radio would like to convert it to a standard 40 channel radio
  • Open your radio and look for a board with a plug going nowhere not even plugged in. Plug it in to the back of the frequency display. Some shops will not ship your e-chip because of how easy it is to convert they want to get paid for it.
Regards, Tony
Apr 29, 2011 | Ranger Communications RCI-6900F-25 CB...
What will coust to have a RCI 6000 F150 REFUBICHT
Hi, my name is John. It will cost you about $150.00 to get it done,and that is cheap. ...Hope this was helpful....
Aug 26, 2010 | Ranger RCI-6900F-150 CB Radio
Communications RCI-6900F-25 CB Radio: the backlight on the lcd display went off...
Wish I had an easy fix for this and a cheap one but I don't the whole LCD will have to be replaced and its not easy or cheap.
May 07, 2010 | Ranger Communications RCI-6900F-25 CB...
Need user manual for ranger rci-6900f turbo
Here is a link that goes to RCI for the complete manual for this model----let me know if you have questions.
If this helped you rate this solution as I do this here for free.
SD TECH
http://www.rangerusa.com/pdf/man6900f.pdf
Dec 17, 2009 | Ranger Communications RCI-6900F-25 CB...
Contact
Is this a base power supply in the radio?
contact me direct at [email protected].
Apr 29, 2008 | Ranger Communications RCI-6900F-25 CB...
Radio Communications Logo
82 people viewed this question
Top Ranger Radio Communications Experts
normis101
John L radiodude365
Are you a Ranger Radio Communication Expert? Answer questions, earn points and help others
