Question about Samsung SL502 Digital Camera
My SL502 camera's lens won't open or close properly is there a way to fix it?
Posted by cecilybrooke on
D. Floyd Kolb
  • Samsung Master
  • 43,501 Answers
Here is a tip that I wrote about How toget a Digital Camera Lens to work again
Steps toRepair a Digital Camera Lens
heatman101
Posted on Jun 29, 2011
How do I fix lens error problem on the described camera?
hi,
lens error occur normally when it fell or the lens shaken, if so open the camera, take the lens unit out, disassemble the lens unit, then fix it again properly. example below:
(this is not the told model)
Dec 10, 2015 | Nikon Coolpix S3000 Digital Camera
Camera lens wont close
That is a lens error. Please see this video for troubleshooting steps.
Jun 08, 2013 | Cameras
Shutters on the lens won't fully open
Stuck automatic lens covers are fairly. But usually it's very easy to fix, without even opening the camera. See this link for troubleshooting steps for this problem.
Dec 14, 2012 | Kodak EasyShare C633 Digital Camera
Won't stay on
Sound like a stuck lens problem; check here about fixing-lens-error-on-digital-camera.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Sep 03, 2012 | Fuji FinePix A330 Digital Camera
Nikon p2 lens erros lens won't open
This link can find details about everything you can try to fix it without sending it to a repair shop: Fixing-lens-error-on-digital-camera
Hope helps.
Aug 14, 2012 | Nikon Coolpix P2 Digital Camera
Shutter button will not depress it says that the lens is either locked or not there
Today's digital cameras are smart. They won't operation if the lens cover is in place (or closed), nor if there is no memory card in place. So ...
  1. Check that the lens cover is "open" or removed. (Open and close several times to be sure it's not stuck or jammed.)
  2. Then check that you have a memory card inserted, AND that it is properly formated (that is, that it is prepared to record images; see your instruction manual for details.
I hope this helps.
Apr 05, 2011 | Cameras
Last time I tried to turn on my camera (Samsung SL502) the lens came out but the screen didn't come on. I hit the power button again and nothing happened, now the lens is extended and won't go back...
Sounds like the lens mechanism is stuck - mine does the same thing after my 2 year old dropped it on the cement. Looking for a replacement lens now, but not having much luck. Read the previous posts for other solutions. Good luck!
May 28, 2010 | Samsung SL502 Digital Camera
Samsung SL502 Digital Camera Logo
266 people viewed this question
Top Samsung Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
k24674
Are you a Samsung Camera Expert? Answer questions, earn points and help others
