Question about Mad Catz PS3 Bluetooth® Headset Wireless Headset
Bought mad catz wireless usb headset ft bluetooth on sunday, put it on charge all day sunday and there is no red light at all and when i hold the call/power button nothing at all happens :( help please
Posted by donna_sadler on
Anonymous
  • 713 Answers
It can be deduced from your problem that the bluetooth headset you purchased is mal-functioning as a result of the fact that it has a factory default,since you havn't even used it for once before the problem occured.
The only solution is to take it back to the point of purchase to get a replacement,because if you try to fix it now you'll void the warranty that came with it.
Thanks and have a nice day.
Posted on Jun 29, 2011
1helpful
So i bought the Mad Catz 8860 model, the black and silver one. i went home used it, worked fine... a couple months passed since i used it, i went back to play with it and its not working. i plug it in to...
Hi Matthew,
With those headsets that think is a known issue.
If nothing happens when you hold down the answer button then the battery must be out (or the headset is faulty).
If you tried to plug it into a USB on a PC to charge it, and the red light does not stay on then I'm afraid it became faulty.
All you can do now is to get back to the retailer who sold it to you and get a replacement for it, or if the retailer cannot help you consider getting back to MadCatz requesting a replacement if it's still within warranty.
Hope it helps.
5helpful
The mad catz blue tooth mic #8860 wont charge how can i fix it?
Try to charge it on a USB on the PC, If the red light doesn't stay on, meaning it's charging, then you have a faulty headset and you'll have to contact your retailer to ask for a replacement.
Unfortunately this is a know issue with this headsets...
Hope it helps
1helpful
I cant connect my headset
Have you charged headset via usb cable plugged into ps3...when charged press + hold silver telephone symbol...a blue pulse light should appear on headset..go to menu in ps3..to pair devise [headset] with Bluetooth.
2helpful
Lost instruction manuil for my mad catz bluetooth wireless headset
Be sure the the headset in in 'Pairing' mode.
When in pairing mode, the light should be flashing red and blue or have a steady blue.
The put most headsets in pairing mode, turn headset OFF, then hold the power button until it goes into pairing mode as discribed above. Then you can discover it with your phone or PC. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
You can obtain a copy of your user manual by locating the FCCID on the label directly on the device, then then going to the FCC Website - https://fjallfoss.fcc.gov/oetcf/eas/reports/GenericSearch.cfm
Be sure to put the first three characters in the first box and the rest (including hyphens) in the second box.
Why wont my headset blink the blue light
Hi there...
It's probably not charged enough.
Make sure you plug in to your USB connector, and charge it before you try turning it on again.
Hope I helped!
Tom
MadCatz8860 Won't Charge
when you buy it for the 1st time, charge it up for double the reckemended 1st charge
Mad Catz PS3 Bluetooth® Headset Wireless Headset Logo
Top Mad Catz Radio Communications Experts
eradiostore
eradiostore
Ekse
Are you a Mad Catz Radio Communication Expert? Answer questions, earn points and help others
