Sounds like you have an intermittent antenna problem.
Open the case and check the wire that goes between the antenna connector and the circuit board. Check both ends of the wire and make sure both ends are securely soldered. If OK, make sure the coax cable is good. Inspect the antenna installation for problems.
Not really enough information given to precisely locate the problem.
....Don at NTCB, Inc.
