Namco Warhammer Mark of Chaos Battle March for Windows Logo
Posted on Jun 28, 2011
Keep getting error messages saying please insert the correct disc whenever i try to run the game. this happens with the original mark of chaos and it's expansion pack battle march, also the gold edition. currently using windows 7
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 30, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
804
Points
Oi - u gotta get, latest patches, then latest no-cd crack. the no cd keys, for appropriate versions, are on many sites - its legal if you like me bought the bloody game cos u dig warhammer and its a piece of poo.
fact is NAMCOM gave up support for this title for a long while ago.
so install, patch, then no cd patch, only trouble i've had with windows 7 has been graphics related since.
1helpful
System settings were lost
System settings were lost:
You need to reset the time and date from the Nintendo GameCube Main Menu. To access the Main Menu, turn the power ON while holding down the A button on the controller. Follow these steps to reset the time and date:
From the Main Menu Screen, go to the Calendar Screen by pushing RIGHT on the Control Stick.
Press the A Button to display Calendar Menu choices of Date or Time.
Use the Control Stick (UP or DOWN) to highlight your menu item and press the A Button to select your choice.
Use the Control Stick (LEFT or RIGHT) to highlight the number you want to change, then (UP or DOWN) to adjust the value.
Press the A Button to accept your choice.
Press the B Button to return to the Calendar Menu or the Main Menu.
Pressing the B Button before accepting your choice with the A Button will return you to the Calendar Menu without changing the settings.
If the same error continues to happen, you will need to have your system repaired as it is likely you have an internal battery malfunction. Please use our convenient repair options.
Wrong Game Disc:
This message happens when a Game Disc has been removed while the system is on, and a different Game Disc is inserted. Re-insert the original Game Disc.
No Game Disc:
This error can occur when the Game Disc has been removed while the system is on and then the Disc Cover is closed. Follow these troubleshooting steps:
Ensure the game is inserted correctly. With the power turned off on the system, replace the Game Disc in the system, printed side up. Press down gently on the Game Disc until it locks on the center hub. Close the Disc Cover and press the power button ON to see if the game comes on the screen.
Determine if this happens with more than one game by inserting a different game into the system.
If the error occurs with all games, follow the Multiple Game Disc troubleshooting.
If the error occurs with only one game, follow the individual game disc troubleshooting.
WII unit will not read disk when put in. Screen says there is an error and to remove disk but gives no other directions. What may the problem be?
    "Unable to read the disc" or "Disc could not be read" Messages
    If you are getting one of the above error messages:
    • This message can display if you eject a disc during game play. If this is when the message displayed, make sure that you return to the Wii Menu before changing discs if you wish to play a different game.
    • If your Wii console is laying flat, it may be positioned upside down. Ensure that is positioned right-side up: the game disc slot should be above all three buttons and the SD Card slot.
      • If your console is placed vertically, the disc label will face to the right.
      • If your console is placed horizontally, the disc label will face upwards
    • Check our list of specific game issues to see if there is a known issue with that particular title.
    • If you know you are inserting the Game Disc correctly, but are still have the same problem with only one game (or if you only have one game), try cleaning the Game Disc by following the disc cleaning procedures (click here).
    If the above information did not resolve the issue or it is happening with most or all of your games, a repair is necessary. Please note: So that our technicians are able to duplicate the issue, please include at least one sample game disc that causes this message to appear when played. Click here to set up a repair.
Installed game , go to play and error message pops up reading: Wrong Disk Inserted Please insert the original Gold Pack CD/DVD
Did the game come with more than once disc? You may have tried inserting the wrong disc.  If that isn't the case, you may need to download a crack for the game.
Go to this link:http://m0004.gamecopyworld.com/games/pc_sw_empire_at_war.shtml
And download the file that says "Empire at War: Forces of Corruption [MULTI] No-CD/Fixed Image"
Replace the .exe file in your game directory (normally C://Program Files/"game") with the one that the crack included.
Hopefully your game will run now!
2answers
The disc is unreadable but dosent say clean disc or anything
"Unable to read the disc" or "Disc could not be read" MessagesIf you are getting one of the above error messages:
Unable to read the disk keeps coming up
3helpful
2answers
MY CONSOLE KEEPS SAYING CAN'T READ DISC
The most common reason for the games not reading discs is a bad drive. The following website sells the drives and does installs:
store.richspsxparts.com/wiiredvddr
This drive should fix any reading issues you are having with your games, or issues inserting your games or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your game including a new laser. If your discs are not ejecting, or you cannot insert a disc -- or you can insert a disc but it will not load, this is what you need to get your game going again!
Take care.
7helpful
I get a "Data Disc" message when I press record.
have you purchased the correct blank discs? sounds like you've inserted discs that can only be used on a PC. these players can only record onto blanks bearing the "compact disc digital audio" mark. these are for use on home audio recorders. hope this helps?
1helpful
2answers
Sims 2 double deluxe insert original disc error
2 disc nhl hockey by ea sports for pc. everytime I try to play it keeps saying install the correct disc in to the drive and click ok. I do but it doesnt recognise it. Is there something I can do?
Error message on wii
what is the error message exactly? Are you certain you are inserting the disc correctly? Label to the right?
To install wii fit
    "Unable to read the disc" / "Disc could not be read" / "Eject the Game Disc" Error Message.
  • If after reading the above information you are still unable to play a game disc, please call 1-800-255-3700 to discuss available options.
Top Namco Video Game Consoles & Games Experts
Sean Wright
Sean Wright
john h
Aron
Are you a Namco Video Game Console and Game Expert? Answer questions, earn points and help others
