Hi The issue is with the water not draining as something might
be blocking the drain pump assembly thus the water is leaking. To solve this
issue you'll have to take the front lower access panel out and then clean the
drain pump assembly completely, also clean the impeller and chopper assembly
located at the bottom of the unit. After this is done the issue should be
resolved, if not then check the float switch mechanism and make sure that is
fine. Hope this helps...please post back for further assistance. Daniel
I am just experiencing the same problem with the same model. I cleaned out the impeller and chopper assembly. Would a deficiency with the pump gasket cause leakage through the bottom? I can see water leaking between the ring lock the bottom of the impeller bowl. Also, how can i tell if the float switch mechanism is fine?
