I suggest you use vinegar acid.
You need a solution with half part water and half part vinegar acid.
1) pour 4 cups of water into your coffee machines water tank.
2) pour 4 cups of vinegar acid into your coffee machines water tank.
3) turn on your coffee machine to decalc.
4) refill tank with clean cold water and let it run through ( 2 times)
REMEMBER !!! ALWAYS POUR ACID into WATER !!!! AND NOT THE OPPOSITE !!!
If you pour water into acid it can explode and make terrible damages and cause chemical burns!!!
Hope this will help ypu
SOURCE: Need a replacement carafe for the Cafe Noir coffee pot.
I've replaced my coffee pot from my local Ace Hardware!
I'd call first!
Good Luck!
SOURCE: Cuisinart DCC-1150 series coffee pot how to clean reservoir
Hello dhubert14,
This is a really common problem with the cuisinarts. I am most familiar
with the DCC-1200, but you may be able to solve the problem. This an indication that something is plugged up. Open the top of
the unit and in one of the corners you should find a filter stick or
column that is removable. Pull it out and open it up to clean out the
clogged up carbon filter in there. (You can later buy a new filter on
Amazon.) Clean out the debris from the bottom of the cavity. Replace
the stick into the cavity once cleaned. Now it's time to run through a
solution of 2 parts water and 1 part vinegar. Do this once or twice
with fresh solutions, then with a pot of fresh water. When the filter
stick is plugged up the sensor says its time to clean it, but most
people don't know about this fix. I hope this is really helpful to you, dhubert14. Positive feedback is appreciated. Good luck. NormanZ
SOURCE: coffe residue inside coffee pot
Add some automatic dishwasher detergent ( maybe 1/4 cup) and fill the rest of the pot up with very hot water. Swirl to combine. Let stand for a few hours. Use a bottle brush to scrub the pot. Or get some denture cleaner tablets and throw them into the pot with hot water. Let stand a few hours or overnight, then scrub with bottle brush. I've tried both methods on my coffee pot and both work great for me.
To clean your metal coffee pot you can pour boiling water into the pot and add a few drops of liquid dishwasher cleaner. Leave it to sit overnight and in the morning tip it out and rinse it out carefully before you use it.
