Question about KitchenAid Dishwashers
Water does not inter dishwasher - KitchenAid Dishwashers
Posted by metzsue on
Anonymous
    Scholar:
  • 70 Answers
Hi, there is a Floater inside the tub protecting against overflow. when it is pushed up (by too much water) or stuck by debris, and does not fall down to its inactive position, it can prevent water from filling.
Make sure there is no debris,and move the floater up and down until it falls down in its normal position.
There is a floor cover underneath the door, it has a repair manual glued to it on the back. you can use "diagnostics" mode by pushing a specific sequence on the front panel, allowing you to go through each cycle in an accelerated way.
Posted on Jun 28, 2011
Cycle taking much longer than normal
The most likely cause is the interal water heater is not working or if using hot water direclty in the inlet then the water temperature is below rerecommended level.
Aug 30, 2012 | AEG 24 in. Favorit 50730W Free-standing...
Water want drain out washer
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Mar 21, 2011 | GE Dishwashers
Kenmore 18 in. dishwasher is not spraying water and the sprayer is not spinning
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Sep 25, 2010 | Kenmore 18 in. 14432 / 14439 Built-in...
Hi, The timer lights up on the door when wash cycle is pressed --inside fills with water but after a minute no action -it won't keep going and the timer freezes but does not shut off the drain button won't...
sounds like the touch panel/ before replacing it ch the ribon connections . where it plugs into the pc control . use a ereaser to clean and replug . . . also make sure the door inter lock is working properly .. mm
Dec 18, 2009 | Maytag MDB9600A Jetclean II Built-in...
DW won't start
ck the door inter lock / they hace a new improved one . if its hard to release handle its probably bad . very common .. mm
Dec 07, 2009 | Electrolux EWDW6505GS Fully Integrated...
Water comes in but does not wash the dishes no pressure
It could be a few problems, first of all does the water circulate at all, if not then you most likely have one of two problems, it is either a plugged pump, or the washer arm in the bottom of the dishwasher is plugged, first take the arm loose by turning the big nut at the bottom of it loose and take it too the sink and wash it out as best you can......reinstall the arm, try the dishwasher, if it still does not work, then you have too remove the pump under the washer and clean it out, also you should be running a dishwasher cleaner every six months..........you can purchase this at any grocery store, walmart, kmart, in the dishwasher isle...........hope this helps.
May 25, 2009 | Maytag 24 in. MDB5600A Jetclean II...
Oil in hose intercooleer to throttle body 940 turbo
U have a serious turbo seal failure problem.
Mar 01, 2009 | 1992 Volvo 940
Problems with my dishwasher whirlpool gold GU75xtvyo
If you are certain that the power is being delivered into the dishwasher and it is new / under warranty, I recommend that you do not crack open the dishwasher to search for the problem. You might void said warranty.
Contact the service number inside the owners manual and press for on-site resolution.
Oct 26, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
Kenmore Elite Dishwasher 16939
I have the same model dishwasher with same problem. The gasket first came loose just after my warranty expired. The stainless steel and heat don't make for a good combination with the glue that holds the gasket in. My husband works with caulk and the like. He found a clear gel of some sort to get everything to adhere. It's had to be reapplied. I just make a habit of making sure the gasket is seated in its track and watching if dishes on top rack catch the gasket when I pull rack out.
See www.repairclinic.com, item #1065754, White silicone adhesive, specially formulated for use in the dishwasher to adhere tine tips & door gaskets. It's an accessory for this dishwasher. I don't know if Sears Parts Direct offers it. Sometimes their price is lower.
From above website it costs $14.55
Dec 12, 2007 | Dishwashers
Dishwashers Logo
87 people viewed this question
Top KitchenAid Dishwashers Experts
Michael Thomas
Michael Thomas
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
