Question about Amana D545M Dehumidifier
I have an Amana D545M Dehumidifier that I purchased in Fall of 2008. My problem is that all of a sudden there's no power to it. no lights nothing?? i tried plugging it into other outlets and still nothing. do I have to replace it already???
Posted by valeriehgc on
Matt Heinz
    Sergeant:
  • 229 Answers
Probably a bad circuit board. Amana is junk..........
Posted on Jun 28, 2011
Testimonial: "Extremely helpful with my problem with my dehumidifier and decision making."
  • 4 more comments
  • valeriehgc Jun 28, 2011
    So do i have to buy a new humidifier or is getting a new circuit board the way to go?
  • Matt Heinz
    Matt Heinz Jun 28, 2011
    I would look into replacement because the mark up on circuit boards is very high and hard to come by in certain circumstances. It will be cheaper and less stress buying new dehumidifiers are very cheap and disposable.
    I was looking at the ratings for them how is the Soleus Air (30 pint), it seem to have gotten good ratings, but who knows. what is your reccomendation? I need all the info and help I could get. I appreciate it.
  • Matt Heinz
    I would definitly go with Soleus Air they seem to be pretty good but all dehumidifiers are made cheaply so they are affordable. All these companies are into cost savings and they keep cuting down on materials and raising the price and they wonder why they have so many problems.
  • valeriehgc Jun 29, 2011
    Soleus Air it is. Thank you so very much for your advice, it's very much appreciated
  • Matt Heinz
    Matt Heinz Jun 29, 2011
    No problem how about a rating if you dont mind.
I have an amana d545m in the crawl space at my lakehome...when i went to check on the furnace filter, i noticed it was not running and has no power...how and what do i check to diagnose the...
First, make sure that there's power to the unit. Has a circuit breaker in the circuit breaker panel been tripped? If so, unplug the unit before resetting the breaker. Also, check the receptacle or extension cord that you're using to power the unit, as it may be damaged.
If you have power to the unit, it may be that some critter or insects have gotten into the unit and shouted it out. In which case, you're lucky that it didn't start a fire. It's not a good idea to leave the dehumidifier running unattended for a week or more.
Hope this helped you troubleshoot and solve the problem. Thanks for choosing FixYa.
Sep 13, 2011 | Amana D545M Dehumidifier
Where do you get Curcuit Broad D545N Dehumidifer and a bucket Switch
Its not worth the money. the cost of those two parts exceed the cost of a new one. Dont buy amana again they have very poor quality.
Jul 20, 2011 | Amana D545M Dehumidifier
Is there any way to run automatically. . . where when it reaches humid per cent it shuts off? Can you rig to run for x hrs. per day and then shut off and restart the next day?
Norman, once the unit reaches the extraction level you have it set for, the unit will turn OFF automatically. However, depending on the humidity level in your home, it may take several cycles of running and emptying the bucket until it reached. After that, it should turn OFF, once the level is reached. Then when the humidity level rises above the setting it's on, it will start up again.
Since your unit is a Manually Controlled unit, there's no safe way to "rig' it to run on with a timer. The plug in wall timers are not rated high enough to handle the load of the dehumidifiers operation. Trying to use one, would fry the timer and possibly the dehumidifier.
If you want all the features you mentioned, you will need to purchase a new electronically controlled dehumidifier.
Jul 05, 2011 | Amana D545M Dehumidifier
Hello do you have 220volts dehumidifier, and wich will be the price, and where can I buy direct
you can get a 220V dehumidifier online. You can order for it and it will be shipped to your home.
Visit the below link in order to get the price for the 220 dehumidifier and also order for it if you wish.
https://www.samstores.com/details.asp?ProdID=10045
Take care.
Aug 12, 2010 | Amana D545M Dehumidifier
DOES NOT DRAIN FROM HOSE ONLY BUCKET
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Apr 15, 2010 | Amana D545M Dehumidifier
I have a two year old D545M dehumidifier that has stopped dehumidifying. The fan operates, but it is not removing any moisture. What could the problem(s) be?
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Sep 01, 2009 | Amana D545M Dehumidifier
Dehumidifier won't start
there should be a trip switch that is not resetting remove the bucket and find the switch. gently lift it up and try again
Aug 13, 2009 | Amana D545M Dehumidifier
Amana d545m dehumidifier no power
replace 24 volt 1 watt zener diode on circuit board. 1n4749 (nte5081a)
mine was hit by lightning and this fixed it.
Jun 23, 2009 | Amana D545M Dehumidifier
Stopped Draining through hose
The hose must be plugged. Empty the dehumidifier, disconnect the hose and see what the blockage is, then remove it or get a new hose.
Apr 22, 2009 | Amana D545M Dehumidifier
Amana D545M Dehumidifier Logo
500 people viewed this question
Top Amana Dehumidifiers Experts
NOEL
NOEL
Tom Chichester
Terry
Terry
Are you an Amana Dehumidifier Expert? Answer questions, earn points and help others
