Fuses | Rating | Color | Circuit |
Engine bay fuse box | |||
1 | 80 | Black | Power supply to main fuse box |
2 | 60 | Yellow | Radiator fan |
3 | 60 | Yellow | ABS |
4 | 20 | Yellow | Daytime running lights |
5 | 30 | Light green | Fog lamp |
6 | 30 | Light green | Not used |
7 | 30 | Light green | ABS |
8 | 30 | Light green | Air pump |
9 | 20 | Light bue | PCM module |
10 | 20 | Light bue | Ignition switch |
11 | 3 | Violet | PCM memory |
12 | 15 | Light bue | Horn & hazard flasher |
13 | 15 | Light bue | Oxygen sensor |
14 | 15 | Light bue | Fuel pump |
15 | 10 | Red | Right-hand low beam |
Passenger compartment fuse box | |||
16 | 10 | Red | Left-hand low beam |
17 | 10 | Red | Right-hand high beam |
18 | 10 | Red | Left-hand high beam |
19 | 7.5 | Brown | Heated door mirrors |
20 | 10 | Black | Windshield wipers |
21 | 30 | Light green | Electric windows |
22 | 7.5 | Brown | ABS |
23 | 15 | Light bue | Reverse lights |
24 | 15 | Light bue | Brake lights |
25 | 20 | Yellow | Door locks |
26 | 20 | Yellow | Main light |
27 | 15 | Light bue | Cigarette lighter |
28 | 30 | Light green | Power seats |
29 | 30 | Light green | Heated rear window |
30 | 7.5 | Brown | Engine management |
31 | 7.5 | Brown | Instrument pannel lights |
32 | 7.5 | Brown | Radio |
33 | 7.5 | Brown | Front and rear sidelights (left) |
34 | 7.5 | Brown | Interior lighting & clock |
35 | 7.5 | Brown | Front and rear sidelights (right) |
36 | 30 | Light green | Air bag |
37 | 30 | Light green | Heated blower |
38 | Unused |
Relays | Color | Circuit | Location |
R1 | Green | Daytime running lights (Canada) | |
R2 | Black | Radiator fan (high speed) | |
R3 | Blue | AC cut-out | |
R4 | Brown | AC clutch | |
R5 | Dark green | Radiator fan (low speed) | |
R6 | Yellow | Starter | |
R7 | Brown | Horns | |
R8 | Brown | Fuel pump | |
R9 | White | Low beam headlights | |
R10 | White | High beam headlights | |
R11 | Brown | PCM power supply | |
R12 | White | Interior and courtesy lights | |
R13 | Yellow | Heated rear window | |
R14 | Yellow | Heated blower | |
R15 | Green | Windshield wiper motor | |
R16 | Black | Ignition | |
R17 | Unused | ||
R18 | Black | One touch window switch | Driver's door |
R19 | Blue | Cruise control cut-off | Central fuse box bracket |
R20 | Unused | ||
R21 | Unused | ||
R22 | White | Fog lights | Interface module bracket |
R23 | Black | Turn signals | Steering column |
R24 | White | Left-hand flasher | Door lock module bracket |
R25 | White | Right-hand flasher | Door lock module bracket |
R26 | Unused |
Bulbs / Lights | Wattage | Type |
Low beam headlamp | 55 | 9006 Halogen |
High beam headlamp | 55 | 9005 Halogen |
Parking / Side light | 5 | 2357A Wedge |
Front turn signal | 21 | 2357A Bayonet |
Rear turn signal | 21 | 1157 Bayonet |
Tail light | 21 | 1157 Bayonet |
Stop light | 21 | 1157 Bayonet |
High mount stop light | 5 | 2723 Bayonet |
Fog/Driving light | 55 | 893 Halogen |
License plate | 5 | 6418 Festoon |
Reverse light | 21 | 1156 Bayonet |
Front sidemarker | 5 | 2357A Wedge |
Glove box | ||
Map light | 5 | 64111 Wedge |
Dome light | 10 | 6411 Feston |
Step/Courtesy light | ||
Trunk/Cargo area | ||
Engine compartment | 10 | 89 Wedge |
Instrument-general | ||
Automatic trans indicator |
