Question about Bauknecht Dishwashers
Everytime we attempt to press a programme button the dishwasher trips our electrical circuit breaker for the house. it does not blow its own fuse. It is almost 17 yrs old and never given a problem.
Posted by mrfester100 on
Anonymous
    Scholar:
  • 70 Answers
Hi, you have a short in the unit take the outer door panel off and look at the door switch and the were connections to the control for a burnt connection.
There are too many items that rely on the same circuit. You will have to get an electrician in to fix this. In the mean time, make sure everything else that is used by that circuit is turned off when you use the dishwasher
Posted on Jun 28, 2011
Can the motor control board cause the house circuit breaker to trip?
It's unlikely. An internal fuse would blow first, I'm assuming. If you've diagnosed this far you sound capable of continuing. Electricity is dangerous!!! I would remove all things from the board, 1 by 1 plug each component into board until the breaker trips. That should pinpoint what is tripping breaker. I would assume a motor.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Apr 04, 2017 | Heating & Cooling
80 series kenmore dryer wont heat - blows cold air during drying cycle. Dryer is all electric.
If your dryer doesn't heat, check these:
Power from the house
Heating element
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Jul 21, 2008 | Dryers
Blowing breaker
In general house hold circuit breaker of the house is 15 Amps or 20 Amps.
Either you have defected (weak) circuit breaker and wiring or bad Microwave oven.
The 99.99 % house hold Microwave ovens pull less than 15 Amps. They may have internal ceramic 15A fuse or 15 Amp internal circuit breaker.
To isolate your problem:
1. Plug your Microwave oven to different areas (different electrical circuit) if the different circuit breaker still trips... your Microwave oven has a short - Most of them has a small ceramic fuse 15 amps fuse.-also check some inter lock switches at door .
2. If the Microwave oven works Ok then you may have:
2a. You may overload the existing electrical circuit, try to unplug some other appliances
2b. You may have bad electrical outlet receptacle (Replace it with the same type , - may need helps from licensed electrician)
2c. Weak or defect house hold circuit breaker. (Replace it with the same type , brand - may need helps from licensed electrician)
Jan 24, 2014 | Goldstar Microwave Ovens
When the dishwasher is drying the load it blows the electrical fuse
There most likely is a problem with heating element or a wire shorting
Nov 07, 2017 | Neff 24 in. S5453X1 Built-in Dishwasher
My dryer still runs but does not heat up (just blows cold air), any idea how to fix? Will it be a thermostat or the heater element itself?
Jan 04, 2011 | Whirlpool AWZ7303 Electric Dryer
2year old ge dryer trips breaker when it's turned on, but sometimes will run a complete cycle before it shuts off.
HELLO THERE
Electric dryers require the use of a 220 volt line. The dryer heating elements run off of 220 volts. An excessive draw of electricity, or a short in the wiring can blow a fuse or trip a breaker. This happens to protect sensitive components from damage, and to help prevent fires. Every other dryer component operates off of 110 volts, the timer, motor, etc. Usually when a fuse blows or a circuit trips, it's because there's to much draw on the power line.
It is very possible for one part of your dryer to work fine, and yet another to have a problem, such as a short circuit. A short circuit may be caused by the heating element, internal wiring, or the main power cord.
To troubleshoot this problem, unplug the dryer and check to see if the circuit breaker or fuse remains on when the dryer is unplugged. If they stay on, it's more than likely the problem is somewhere in the dryer.
If your fuse blows, or the circuit breaker trips when the dryer is unplugged, it's likely the problem is with the circuit breaker, fuse box, or house wiring; contact a professional electrician.
OK I hope this is very helpful for you
Best regards Michael
Dec 01, 2009 | GE DBSR453EBWW Electric Dryer
Keeps blowing the fuse in the house
Try to turn off everything else that is on the same circuit then turn on the dishwasher. If the breaker still trips then the circuit breaker might be malfunctioning or the dishwasher might be defective (in which case the circuit breaker is doing exactly what it is designed to do.) I would bet that it's the dishwasher thats causing the problem. Check with the manufacturer to see if there are any recalls on that model.
Aug 17, 2009 | Creda Dishwashers
Dryer problem
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Heating element
Thermal fuse
Wiring
Mar 11, 2008 | Whirlpool GEW9200L Electric Dryer
Power tripping
First off, lets make sure its not the wiring in your house. disconnect the dishwasher and plug in something else and see if it trips the fuse. also what amps is the breaker rated at?
Nov 02, 2007 | Zanussi 24 in. DA6141 Built-in Dishwasher
Dishwasher tripping the circuit breaker
Andy, leave the breaker off and remove the toe panel (bottom panel) from the dishwasher. Remove the cover of the junction box where the cord connection or wiring is made. Look at the wire caps and see if they are not burnt. Sometimes these connections become loose and arch, tripping the breaker. If so, cut the wires, strip a new end and reconnect. Catriver...post back.
Aug 21, 2006 | Hotpoint 23 in. BF50 Built-in Dishwasher
Dishwashers Logo
230 people viewed this question
Top Bauknecht Dishwashers Experts
ADMIN Canada
ADMIN Canada
ray gallant
Habib Shubber
Level 1 Expert
Are you a Bauknecht Dishwasher Expert? Answer questions, earn points and help others
