Question about LG GSA-T20N DVD±RW Dual Layer Burner
Error Code: 1004 CDB: 2A 00 00 12 DB 20 00 00 20 00 00 00 SenseKey:04 ASC:44 ASCQ:
DJ Skywalker
  • 507 Answers
Checkout the solutions on this forum:
http://forums.techarena.in/xp-hardware/647582.htm
Posted on Jun 28, 2011
Dvdr cant burn audio
Update the driver of your dvdr so that you can make sure that the operating system is communicating with the dvd. You can use RadarSync to automatically update the driver.
David
May 14, 2013 | Dell XPS M1330 Laptop
Burn dvd
put the dvd in... select files you wish to burn to dvd... then burn them.
May 14, 2013 | Dell XPS M1330 Notebook
My gsa-t20n will burn regular disks but will not burn DL disks all of a sudden...it burns most of the way then Nero says it cannot finalize disk. 22:48:29] NeroVision [22:48:29] NeroVision 10:36:44 PM ...
Hello there jpd0490.
Here's your geek-steer ...
There are principally two chief causes for this type (calibration) of burn failure:
  1. Inadequate quality media (disks). Verbatim is always a solid choice. However, more important than the brand-name disks are sold under, is the actual manufacturer. You can determine this with the aid of a little software tool called "DVD Identifier". There is an entire sub-culture devoted to tracking the best media available, right down to the manufacturing lot level.
  2. Drive failing. Since you say that it works consistently otherwise, this option is unlikely.
Good luck, and please do post back ...
  • to let me (and interested others) know how things worked out,
  • to provide clarification or feedback,
  • if you have ANY further questions.
"Today's the best day of my life ... and NOW you're part of it!"
Via-con-Dios and Godspeed -- Geekinator (aka Craig).
Oct 10, 2009 | LG GSA-T20N DVD±RW Dual Layer Burner
Error burning iso file on Roxio Creator Basic ver 9.0.117
I found that burning images with roxio can be a bummer, plus it is slow. Here is a free program that works great:
http://www.imgburn.com/index.php?act=download
Aug 03, 2009 | Roxio Easy CD & DVD Burning
Burn errors cant get drive to write
It looks like from error codes that yoi may have a hardware error, or a disk format problem, if this is only burning problem you have on pc and it worked before, then uninstall and reinstall Nero, info gathered from here,
http://www.isobuster.com/help.php?help=305
sense code 5 ASC 2c= 5 / 2C / 00 COMMAND SEQUENCE ERROR
5ASC2700=5 / 27 / 00 WRITE PROTECTED
Please give good rating if this helps you or points you in right direction, thanks
Apr 12, 2009 | Computers & Internet
Will start burning CD then says there's an error
there are a lot of similar issues out on the net about this, dells computers I would switch to nero or any other burner software and see if it clears up, you might want to contact dell about it as well as I can see by the net forums its wide spread, could be a limited use lic issue.
Apr 04, 2009 | Dell Computers & Internet
Error burning to Dual Layer DVD
Do you have a dual layer burner, you need one to burn dual layer dvds that may be your problem hope it helps
Mar 25, 2009 | Global Marketing Partners Vhs To DVD 3.0...
Sony DVD RW AW-Q170A Burning Problem Plzzz.....Help me out: i have two drives, 1) Sony DVD RW AW-Q170A 1.70 Ver 2) Sony DVD/CD-RW Combo RYK4 Ver My "Sony DVD RW...
Check that the writable DVDs you are using are compatible (+/-) with your Sony DVD-RAM.
Go to Windows Explorer and check to see if the Sony drive is visible. It may not be connected or the Jumper switch may be set incorrectly.
Check you have drivers installed, take a look in Hardware manager.
Sometimes, it's a little difficult to copy CDs and DVDs when you have more than one burning suite installed - for some reason, they 'just don't get along'. Try uninstalling any suites other than Nero.
Or it may just be that your Sony CD-RW drive is just that, and your DVD-RW drive is just that. So it wouldn't be possible to write DVDs on the CD-RW and CDs on the DVD-RW? Though I would assume Nero would detect that and use your hard-drive as temporary storage.
In Nero SmartStart, have you selected the CD or DVD tab to correspond to the project you're burning?
Jan 07, 2008 | Sony AW-Q170A-B2 DVD RW Dual Layer Burner
LG GSA-T20N DVD±RW Dual Layer Burner Logo
251 people viewed this question
Top LG Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
