Palm Treo 650 Handheld Logo
Posted on Jun 28, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My camera has stopped working on my Palm Treo 650. What can I do to get it working again?
electronic & computer repair& servicre
Level 3:
  • Palm Master 12,061 Answers
  • Posted on Jun 28, 2011
Palm Master
Level 3:
Answers
12061
Questions
0
Helped
4008148
Points
36390
Hi, well you could reinstall the Firmware again, you could restore to factory settings, you could reinstall the software and drivers again for the camera only. Of course ONLY after backing up fully first.
http://www.hpwebos.com/us/support/handbooks/treo/treo650gsm_UG.pdf
Above is your user manual, look in here for assistance,as to how to perform those tasks.
Hi how to unlock my palm 650 to used outside of USA
You can use the Unlock code to Unlock Your Palm-One Tero 650 model Phone,You can get the Unlock code from here
Wickedunlock and follow the instructions and Unlock it step by step..
Palm One Treo 650 Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Palm One Treo 650 mobile phones. If you enter over a certain amount of wrong unlock codes on your Palm One Treo 650 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Palm One Treo 650 with an ACCEPTED SIM Card,
2 - Go to Menu and select "Phone Tool" or "Phone Application",
3 - Type on Virtual Keyboard *#*#CODE#,
4 - Select with PEN "Numer" and Palm One Treo 650 will show that it's unlocked now!
or
1 - Switch ON your Palm One Treo 650 with a NOT ACCEPTED SIM Card,
2 - Enter the Unlock Code we send to you.
or
1. Remove Palm One Treo 650 battery, unplug cable,
2. Switch ON your Palm One Treo 650 with a NOT ACCEPTED SIM Card,
3. 'Sim not allowed' is displayed, click OK,
4. Go to the dial pad, and dial *#*#CODE#,
CODE: The unique unlock code for your Palm One Treo 650.
ACCEPTED : We mean, to use a sim card from the network your Palm One Treo 650 is locked to.
NOT ACCEPTED : We mean, to use a sim card from a network other than the network your Palm One Treo 650 is locked to.
Need unlock codefor palm treo 650
Animated procedure for unlocking the code for your mobile.
Copy the link->http://650unlock.com/unlock/flash_instructions.html
If the above link is not working out for you, you can buy the software from the link below.
Try this link..http://www.foneszone.co.uk/unlock/how_to/Palm/Treo-650.php
Thanks for the rating good luck
Unable to Synchronize with Vista 64 bit
Treo 650 can't be synced to Vista 64 via the cable, but Bluetooth works OK. Details later (I hope).
1helpful
Palm treo 650 phone
Greetings to all. I have just purchased a palm treo 650. It was unlocked so I was told, but it was not a GSM, It was a CDMA, My carrier is T Mobile and I dont know what I could to Make It Work, as t mobile has a sim card and this treo 650 does not. Is there any thing I could do to solve this problem?
3answers
Palm Treo 650 Unlock Code.
Call your service provider.
Treo 650
my treo 650 just turned of the light of the screen.thought it was only battery.i pulled out the battery then put it back again,the light is on and say palmOne with a bar loading.then the light was gone again.try to sign on but nothing does
Hot sync treo 650 Zip-Linq cable
i have the same F***** probelm
Palm treo 650
Hi Sandra Bunch,
Could you inform us which treo do you use? If you use Treo 650 or newer, than you could buy desktop charger beside ordinary palm charger. But if you use Treo 600 there's no alternative than buy the ordinary palm charger. It's easy to get this accessories on the net, you could try MyTreo.net or TreoCentral.com
Syncing a 600 and 650??
I have Treo 600, 650 and old Handspring Visor -- all sync perfectly well using Palm Sync Ver. 4.0.1 software.
Pls help me for power on fail
If your Treo loops or freezes during a soft reset, a system reset may help. Performing a system reset allows you to get out of an endless loop in order to uninstall a third-party application causing the looping: 1. Press the Battery Door Release button and slide the battery door downward to remove it from your Treo. 2. While pressing and holding Up , use the tip of the stylus to gently press the reset button on the back of your Treo. 3. When the Palm Powered logo appears, release Up . 4. Delete the third-party application that you suspect is causing the problem. 5. Perform a soft reset. The wireless features of your phone are not available until you complete this step. Good luck!
Top Palm Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
vince
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
