Sony VAIO GR370 Notebook Logo
Posted on Apr 02, 2017
Well I have a Sony Vaio laptop model PCG-GR370 that I bought about 2yrs. ago and about a month ago it crashed on me and started asking me for the bios password.I dont know the password and the person who sold it to me does not know it either.So I know a little bit of electronics and I opened the laptop to drain the CMOS battery(and yes everything was unplugged) but that didn't work and I've tried several passwords that I found online but they didn't work either.So I ask you guys what else can I do to over come this problem?Is there jumpers on this laptop?Cause if there is I can't find them.Or is there another battery or some type of bios reset button?
5 Related Answers
Anonymous
  • 35 Answers
  • Posted on Aug 19, 2008
SOURCE: CMOS Battery Replacement
No access panel for that. That is located on the motherboard. You will have to take of the keyboard to get access to it.
Anonymous
  • 149 Answers
  • Posted on Dec 15, 2008
SOURCE: CMOS battery
the cmos battery is under the palm rest of the viao....requires you to take off the keyboard and undo 2 screws holding the palmrest on....slide the palmrest off....battery is plugged into the touchpad circuit board
Anonymous
  • 87 Answers
  • Posted on Jan 11, 2009
SOURCE: How Replace CMOS Battery in Sony Vaio VGN-FS742 / PCG-7D2L?
Here is are disassemble instructions for you,
Good Luck
Anonymous
  • 201 Answers
  • Posted on Feb 22, 2009
SOURCE: i need to flush my bios.forgot password. Sony vaio pcg-7g1m
Try This:
Reseat the CMOS battary:
How to Change/Reset a BIOS password Posted on 30 December 2008
Tags: Tech News, Tutorials If you are a normal computer user who has forgot his BIOS password and you are unable to access to your BIOS, then you need a simple way to change your BIOS. Its not that hard because you just need a simple trick to reset your BIOS password.
Open your CPU cabinet after switching OFF the power and then try to locate the CPU battery which can be found very easily. Once you locate your battery you need to remove it once and restart your PC without the battery.
cmos-battery-check.png Note : Once you remove your battery from the mother board, you will find that all your time settings in your computer would be lost, and some softwares may stop working which are based on your computer time.
You need to shut down your PC again and now add back the battery which will enable you the time saving feature and also reset your BIOS password.
Anonymous
  • 61 Answers
  • Posted on Mar 18, 2009
SOURCE: who to bypass sony vaio bios password
It is not easy to unlock Sony Vaio Laptops Bios Passwords.
I was searching and i found this
http://www.spunlock.com
They have remote unlock for sony vaio laptops and have been recomended.
Regards,
I need to replace my hard drive in my Viao PCG-GR370 laptop. Is it possible to put in a larger than 30 GB drive?
below is a link for a 320 gig hard drive for your model, i hope this helps
http://www.upgradecomputermemory.com/ram.cfm//memory/s/sony-vaio/sony-notebooks-vaio-pcg-series/VAIO-GR-PCG-GR-Series-Notebook/VAIO-PCG-GR370/320GB-Notebook-Hard-Drive-for-the-Sony-VAIO-PCG-GR370.html
I want to install internal wlan in my sony pcg-gr380. is it possible? If so how and what product?
I'd give up on that idea. Modern laptops are a nightmare to dissemble, and even if you manage it, the motherboard itself may not have a spare slot for a WLAN card. Buy a USB based WLAN device instead .. much easier.
CMOS battery
Sony Vaio PCG-TR3A, Blue Screen states cannot find operating syst
There should be a factory image on the HD when you try restarting it. Hold down the F8 key or F10 key while its rebooting this should start the recovery process you shouldnt need a windows disk.
Sony vaio laptop model PCG-9W2M
If you go into control panel/system the hardware tab then device manager is the re any yellow marks there to show something isnt installed?
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
