Question about Universal Remote Control Osiris Complete Control Universal Remote
How do I program my mx-350 to run at&t uverse remote?
Joshua Farmer
    New Friend:
    Problem Solver:
  • 19 Answers
Type this address into your "address bar" (long white bar on top of the internet explorer page)
www.universalremote.com/resources/pdfs/MX-350OwnerManual.pdf
Posted on Jun 28, 2011
How do I Program the mx810 to ATT Uverse
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window" to get gathered related posts.
Oct 10, 2016 | Universal Remote Control MX-810 LCD Remote...
I have the rca remote programed to the phillips tv. now i need to program it to the at&t uverse box.
There is no set-up code to AT&T Uverse box, with RCA remote control. You have to select an other remote control for this box.
Jun 07, 2015 | RCA Televison & Video
What can i do? I need help to program my proscan 32la30q tv with at&t uverse remote.
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts.
Aug 17, 2014 | Televison & Video
Uverse remote
Programming procedure is too much to type in here by this window, and is not practical. If you wish to get details; check the site linked here. It have set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
Mar 18, 2014 | Televison & Video
I have a MX-350 universal remote and when I replace the batteries, it won't come out of "TEST" mode.
Could be a bad ground. Run a different ground wire and then try or sometimes the bulb housing is the ground, and the housing is not screwed in proper or it lost its ground somehow .
Mar 09, 2014 | Universal Remote Control MX-350 LCD Remote...
Universal remote mx 980
HI Julia,
I have a link for you regarding your issue programming your other remote to your att STB. Hope it helps
Search Results for program other remote to my uverse
Apr 30, 2013 | AT&T UVerse
Programming AT&T Uverse Universal Remote COntrol
Hi Ted,
You may want to visit this link for your issue. Please make sure you are logged in first for the best results for programming your remote.
Search Results for program other remote to my uverse .
Mar 05, 2013 | AT&T UVerse
Time warner cable box doesnt have a code for maxent mx-26x3
Code for gateway works. I used 206 on my universal remote. I have a Phillips remote.
Aug 08, 2008 | Maxent MX-26X3 Television
Programing Remote
Most Polaroid flat-screen TVs won't program to the Uverse remotes. Try buying a different universal remote that shows coding for both Uverse and Polaroid.
Apr 19, 2008 | LG 47LC7DF 47 in. LCD HDTV
Universal Remote Control Osiris Complete Control Universal Remote Logo
546 people viewed this question
Top Universal Remote Control Televison & Video Experts
Christopher Stearns
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
