Hi, if the water doesn't drain from your dishwasher, check the drain line and pump..
A
clog in the drain line or air gap (if there is one) is the usual reason
that a dishwasher won't drain. Often the problem is at the point where
the drain line attaches to the garbage disposer or household drain
line. If you remove this line, you can clear any debris from the hose
or hose connection. Be sure to reattach the hose before starting the
dishwasher again.
Your dishwasher pump ejects the water. The
pump is usually mounted directly to the motor, then attached to the
bottom of the dishwasher. You can reach the pump from inside the
dishwasher, but first you need to remove the lower rack, the spray arm,
and the spray arm support.
Look for an impeller--a round plastic fan
blade-type of device that spins around. This is the wash impeller,
which forces the water through the spray arm. Beneath the wash impeller
is the drain impeller, which is similar in size and shape to the wash
impeller. The drain impeller pushes the water toward the drain port.
These components make up the pump. If any of the pump components are
defective, you need to replace them.
Hope it helps...
