Dishwashers Logo
Tari Cantwell Posted on Jun 27, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Start won't work. - Dishwashers
Anonymous
Level 3:
Brigadier General:
  • Master 3,513 Answers
  • Posted on Jun 27, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
3513
Questions
0
Helped
867854
Points
10095
Thank you for contacting fixya.com.
A check should be made with the volt/ohmmeter to check if voltage is available to the dishwasher wiring. A voltage check is made by setting the volt/ohmmeter on the 150 A/C scale and placing one probe of the volt/ohmmeter on one wire that supplies voltage to the dishwasher. Place the other probe on the remaining wire. The meter should read 110-125 volts. This would indicate that electrical power was available from the circuit breaker panel to the dishwasher terminal box. If there is no voltage at the dishwasher terminal box electrical wires, the problem could be a defective circuit breaker or fuse, house wiring burned or broken from circuit breaker panel to terminal box. If a defective circuit breaker or fuse is suspected, it would be recommended that a qualified electrician perform these repairs.
Please check this links for an in-depth knowledge to troubleshoot your problem:-
http://www.repairclinic.com/Dishwasher-Troubleshooting?red=Dishwasher-Repair-Help
http://www.acmehowto.com/howto/appliance/dishwasher/diagnose-dishwasher.php
http://www.partselect.com/dishwasher+dishwasher-wont-work+repair.htm
http://www.cookshomeappliance.com/dishwasher_troubeshooting.htm
Please get back to us if you have further query else please accept the suggestion.
Suntracker pontoon won't start and trim won't work
Trim want work ,,want start,, no power
2003 lexus es300 won't start... radio lights and windows work. Tried a jump start, still doesnt work...
Are you saying the engine cranks but won't start, or the engine won't crank ?
If the engine does not crank, you would check for voltage at the starter, the neutral safety switch, and the key switch as well as the ground connections.
My plymouth breeze won't start, won't make a sound, but my lights and horn still works , help me.
any real answer yet? did the problem ever get resolved? i have the same problem with my sister's car. too cold to diagnose tonight, but will post the solution probably tomorrow. since the lights and heater works, but ignition and radio arent getting power, my first guess is there's probably a fried fusible link which controls the 2nd accessory power to the ignition switch. will post a solution soon.
97 gmc jimmy cranks but won't start, have replaced everything possible but still won't start, most of the time the brake lights won't work, or the gauges goes crazy. I have changed relays,...
There are two basic reasons for not starting - no spark or no fuel, both of which are controlled by the ECM. You need to check error codes and these items - for the spark, test it at the cylinder 1 sparkplug; for the fuel check the pressure (if too high or low, problem!).
6helpful
Electronic key on 2008 jeep cherokee says key damaged or key not programmed. car won't start. some things work but radio won't come on. etc..
electronic key on 2008 jeep cherokee says key damaged or key not programmed. car won't start. some things work but radio won't come on. etc..
2answers
Need help Toyota 87 pickup wont start I replace the the ignition coil and distributor it wont start
fuel filter might be plugged if it turns over if it don't its ur starter if that don't work see if ur fuel pump is working
I have a 1998 Ford Windstar. Got in to drive, turned the key to start and 'snap' something seems to have broke within the ignition lock cylinder... all of the accessories are on... the key...
This happened to to me with my ranger. I went and bought in ignition and a junk yard and no problems after that. That way your not out of a lot of money.
1helpful
I have Toyota Tazz 2004,the problem is my mobileser whenever I start it won't and but when I kick start it does start. I went to check if the starter & alternator are working, find out that they...
If you have other key try it. If it still doesn't work the immobilizer has a problem. If you deactivate it anyone with a copy of your key can put it to work. Be sure of what you do.
Top Dishwashers Experts
Mike Cairns
Mike Cairns
