Question about Connex CX-4300HP CB Radio
I have a connex 4300 hp, with a new antanna i left the cb shop and it worked great got out over 15 miles or so but on the weekends i clean out my truck and take my cb home so no one will steal it and when i took it out my hand bumped some of the knobs and i was wondering if you can tell me how to re-set them or do i have to go back to the cb shop? thanks
Posted by damon_reed on
Laron
    Novelist:
  • 146 Answers
Radio setting for connex 4300
1. Band should be on D
2. 10khz switch off
3. PA, AM ,FM switch to AM
Posted on Jul 02, 2011
I have a connex cx-4300 hp cb it will receive but won't send how do I fix this problem
Is there any RF being transmitted, to a nearby radio. also does the TX/RX led change.
There are many scenarios on this..
Loose/cold solder joints on the board.
loose diode on solder side of the IF area..
Bad RF transistors from High SWR..
if you can provide more info.
Jan 31, 2016 | Connex Radio Communications
Connex 3300 hp
no its not the problem but it doesn't help..first, is this a newly purchased radio or did you get it on ebay . if its new send it back its still under warrenty as long as its not to old . iIf you got it on ebay , you're screwed. You can take it to a CB shop and they will fix it for you.I could fix it but I don't have time to explain the procedure .
Sep 18, 2013 | Radio Communications
Connex 4300-400 how many amp can they pull
easy way to find out.. is use the wattage divided by the voltage used will give you amp draw.
so if you in a vehicle.. most are either 12-15 volts.
the radio in theory say its doing 400 watts.
400/12 = 33.3 amps
normal cb that can do 12watts your looking around 1-2amp draw.
Jan 25, 2013 | Connex 4800-DXL 480-Channels Base CB Radio
Wire 4 pin turner plus three mic up
pin 1 gnd
pin 2 audio
pin 3 tx
pin 4 rx
Dec 24, 2012 | Connex CX-4300HP CB Radio
Connex 4300-300 squeals in talk back mode
turn rf gain up and the mic gain down until it stops squealing.
Jul 14, 2012 | Connex Cb Faceplate Sticker-fits 4300-300
What do you think is wrong with my connex 4300 HP, I turn it on it powers up,but no adio it has static. It seems to have a dead key and swing. Any ideas? Thanks Jim
You will need an SWR meter to check your antenna. FIRST.
I would find help at a local cb shop.. They SHOULDN"T CHARGE to help you SET the swr. only if you need a part or something ..
I don't charge to SET SWR"s .. only if the cust needs a insulating washer or another antenna, or new coax, so-239 etc... I would be glad to help you.. let me know if we can CB Shop Temple, TX
Any shop shouldnt charge you just to see if it works!!
Nov 25, 2011 | Connex CX-4300HP CB Radio
I have a 4300 HP cb radio and can't find my warranty papers. I need to find out if its still under warranty.
they will go by your serial numbers on the back of the radio. I have the number at my shop for connex repair if you'd like to give me a call. 904-845-3847.Mel
Oct 05, 2009 | Connex 4600 Base CB Radio
Have a connex 4300 hp and can`t find anyone to tweek it right!
tell me what you have had done to the radio? There is a shop in texas that specializes in 10 meter and they can do that for you email [email protected] and he will give you the info and what he can do for you.
Mar 08, 2009 | Connex 3300 240-Channels Base CB Radio
Connex CX-4300HP CB Radio Logo
356 people viewed this question
Top Connex Radio Communications Experts
Tony Raia
Marvin
Marvin
Are you a Connex Radio Communication Expert? Answer questions, earn points and help others
