Question about Whirlpool Duet Sport HT WFW8400TE Washer
Whirlpool Duet Sport Model WFW8300SW0 basket won't
Posted by davidxsandra on
ZJ Limited
  • Whirlpool Master
  • 17,970 Answers
The following list of codes indicates an electronics communication problem with the washer: - Duet HT washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
I would first replace the door latch/lock assembly, a number of users have and it fixed the F-11 error code completely. Its the cheapest part for this problem.
Hope helps.
Posted on Jun 27, 2011
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    My front loading Crosley washing machine is showing error code 21. What does that code mean?
    Can't remember the exact error code, but my crosley front loader would not spin. I found out this was because all the water was not being pumped out. I wash a lot of dog blankets and found out the drain basket was completely blocked. I was able to remove and clean from the back and this fixed my problem. I guess it could be the pump but check this basket first. The way I did it from the back was hard so I suspect there is a better way to access the basket.
    Jun 23, 2014 | Crosley CW5000 Front Load Washer
    Why would a whirlpool duet sport model number WFW8300SW05 starts fine stops during cycle. No error codes door locked red light on water in machine.
    you have a plugged or partial plugged drain pump for sure. maybe there is a 20 stuck in it this time! easy to find just follow the drain hose back and you will find your pump.
    also could be the cycle your using has a bad area in timing cct. check a different cycle like the delicate cycle and that will confirm pump or cycle
    Jun 10, 2014 | Washing Machines
    WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
    WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
    Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
    Error code Sd (or 5d)
    It means Suds Lock(Overdose of Detergent Detected During The Wash Cycle).If suds are detected continuously by the pressure switch during the drain or spin phases,the washer will fill 4 litres of water and during 5 minutes the unit will rest without tumbling,the water will be drained and it will try to spin or drain again.
    If too much detergent was used:
    – Run the unit through a Rinse/Spin cycle.
    – Run a Normal cycle without adding any detergent.
    This should clear the unit of the excess detergent.
    1. Check the drain hose and make sure it is not plugged or kinked.
    2. Unplug washer or disconnect power.
    3. Check wire harness connections to the drain pump,pressure switch and Central Control Unit(CCU).
    4. Check/clean drain pump filter of foreign objects.
    5. Plug in washer or reconnect power.
    6. Check drain pump.
    7. Check the pressure switch.
    8. Verify CCU operation by running a Diagnostic Test.
    Apr 11, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
    Hi. Whirlpool washer (Duet front load) GETS F11 error code. Any ideas as to the cause and repair?
    Pull off bottom panel, there should be a schematic and trouble shooting guide to help you through any questions about you fault code.
    Jan 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    I have a whirlpool duet washer that will not spin at high speed and shows error code f 06
    Error F06 is Drive Motor Tachometer Error
    The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes. Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
    • Check the Drive Motor
    • Check the MCU
    • Check the Wire Harness
    Oct 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool LA6800XTWO will not drain or spin
    Need a new drain pump. I just had this problem. found a drain pump on ebay for 60. Replaced and running mint again. don't keep trying or you will burn out your motor.
    May 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    The motor does not engage in at all
    The F 11 code is a water fill code. Check the water to make sure both lines are on. If their on then turn off take hoses off the water inlet valves in the back and check the screens. If your screens are clean then you probably have a water inlet valve problem. Are you able to open the door to get your clothes out? If not I can tell you how to get it open.
    Jan 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool duet sport wfw8300sw00 f-21 error
    Unplug the machine. Unscrew the 3 screws under the front edge of the washer. The service technician manual is attached to the panel that slides down and off. Find F21 code. See suggested procedures. Note: My drain pump filter had a baby wash cloth in it along with some change that was disrupting the flow. It is exceptionally easy to remove, clean, and reinstall. Just line up installation notches when reinstalling. Whirlpool should have mentioned this filter in the User & Care Guide, but I could not find it anywhere in there.
    Mar 24, 2008 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
    Whirlpool Duet Sport HT WFW8400TE Washer Logo
    1,345 people viewed this question
    Marvin
    Marvin
    Gerry Harvey
    Gerry Harvey
