Posted on Jun 27, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hello, The printer works continuously for several years, I mean we already know most of the problems. But this time we encountered a problem that is not here yet, plus she has no problem number. When we print out everything works properly but 2 minutes later, the printer suddenly prints are not sequential, it does a line and all stops and print. Strange problem I'd love some advice. Thanking you in advance. Danny.
Victorman
Level 3:
  • Office Equip... Master 846 Answers
  • Posted on Jun 27, 2011
Victorman
Level 3:
Answers
846
Questions
0
Helped
309200
Points
2441
I do not understand what you are saying. You say the machine works ok. then 2 minutes later it starts up on its own and prints out something but not in sequence and on this print there is a line then the printer stops then prints again?????
2answers
I have Epson NX515 that won't print because it says the printer is "offline". How do I get the wireless printer "online" to print?
Epson Printer Offline on Windows 10 is a printer problem you probably might have encountered one or several times when while using your Brother printer. I determined to include this since I have seen a lot of complaints about this failure message.
Epson Printer Offline on Windows 10 usually relates to a printhead problem and an error message shown will flash on the Screen. lights will keep on flashing as a sign of this Offline on Windows 10.
Caused by some foreign trash inside the rollers of a printer or due to paper jam in Printer and many more PC causes.
Steps to Fix Epson Printer Offline on Windows 10:-
1. Click on the Start button on your computer, and then click on the Devices and Printers option.
2. Now right-click your Epson printer icon and click on the See What's Printing option on your screen.
3. Check Full blog for the step by step solution.
If the problem continues, check this blog or call Brother Printer support services or a Printer Support to stop more printer damage. The number is in this blog- Epson Printer Offline on Windows 10
If Epson Printer Offline on Windows 10 is not resolved, this might mean there's waste within the printer's inside. Call the customer services our check this Blog for a full solution.
1helpful
2answers
Machine error 28
Well it's a low temp error for the fusing assembly. Sounds like you already had it in Maintenance Mode. Sometimes those errors can only be cleared out by entering maintenance mode and pressing 9,9 to exit out. Should then start the normal warm up procedure. If the problem continues then reseat the fuser or take it out and measure for continuity across the lamp and thermostat. The service manual also recommends checking the line voltage. Basically make sure it's plugged straight into a wall outlet and no other large power sources on the same circuit. Example, another copier or this time of the year a small space heater.
Maintenance Mode enterance Press Menu/Set and Black start button and Up arrow 4 times. Machine will read Maintenance on the display if done correctly. Press 9,9 to exit of the mode and the machine will attempt to restart normally.
OR
In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On :Brother Printer Support
Every time i get message "Spooler SubSystem App has encountered a problem and needs to close. We are sorry for the inconvenience."
hello
your printer spoooler is not running means it not working you have to restart your computer or you have to manually start the printer spooler of the printer in the system.
just leave comments
thanks
1helpful
Red light blinking
yes, you have to replace toner cartridge. If the problem persist just vizit autorized service!
1helpful
2answers
Canon pixma ip4600 is it reliable. it's my 1st. m/c
Looking at the number of problems posted for different printer makes I would go for an epson.
HP Officejet Pro 8500-- HP CUE-Scanning Flow Component has encountered a problem; what does this mean & how do I fix it?? It will NOT scan. It will print, but NOT scan.
you may had a scan job and you canceled and still on the mem. try to reset the scanner/printer and go and check your printer files and delete all pending jobs and reboot your computer and printer. let me know if that work and please remember to rate my service so I am able to continue provide quality service and improve on it with your help. God bless
Speedometer does not work properly
I have not heard of this before but I do know there is such a wide spread problem with the cluster (speedo) GM has extended warranty on several years and I expect they will add more years as time goes by.
Many of the problems I encounter have been speedo's showing a faster speed than actual, 100mph plus.
Good Luck
Dave
1helpful
Lexmark c510 error message ;83 photodeve cart missing
See User Reference
http://www.lexmark.com/publications/pdfs/c510/eng/userref.pdf
Understanding printer messages
pages 184 and 185
"Message:
83 Photodev Cart Exhausted
What this message means:
The photodeveloper cartridge is completely used.
What you can do:
Replace the photodeveloper cartridge.
See also: Replacing the photodeveloper cartridge [page 73]
Continuing below
Message:
83 Photodev Cart Life Warning
The photodeveloper cartridge is nearing the end of its life.
What you can do:
• Press Go to clear the message and continue printing.
• Replace the photodeveloper cartridge.
Continuing below
Message:
83 Photodev Cart Missing
The photodeveloper cartridge is either missing or incorrectly
installed.
What you can do:
Correctly install the photodeveloper cartridge to clear the message and continue printing.
See also: Replacing the photodeveloper cartridge [page 73] "
Check Carteidge Light Come Out without any change on hardware
sometimes you have to look through the settings and allign the cartidges.....check the options on the litle screen on the printer....itll be in settings....let me know what hapens
Tally printer form feeding continually on its own
When was the last time it was services? It may be nothing more than a dirty paper sensor. Also, some Tally printer sensors require adjusting, it may be a simple matter of adjusting a sensor setting. That would require a technician with the manual and settings chart. Let me know how it goes!
k24674
ADMIN Andrew
ADMIN Andrew
