SOURCE: LaCie 500 GB hard Drive - does not register on my desktop
if it is a USB (or you have low disc space), it does take longer to show up on desktop and patience is required... on my iBook it takes over a minute for my Brick to show up... Whether it is USB or firewire, do try another cord (I had similar problem with my lacie firewire external... I used a different firewire cord and all was fine. If you have tried these already, I hope you find the answer... good luck
SOURCE: Lacie drive won't mount
Ive solved the Whole Lacie wont mount problem.... Thanks to Lacie support center, Best Buy, The internet and several Tech shops I took my crashed lacie d2 quadra 500 GB hard drive to for help when it crashed. They didn;t help and none of the stuff I bought helped either. Here is the solution: Take any of your crashed lacie Hard drives (That are clicking and making a noise to a Windows OS) FOOTNOTE: NO MATTER WHAT ANYONE SAYS, YOUR LACIE HAS NOT CRASHED AND DOES NOT NEED DATA RECOVERY$$$$$$$$ Take it to a Windows (XP worked on mine) install your lacie one button disk, after its installed properly, Run the lacie one button recovery by clicking the blinking and clicking switch on the hard drive the program will come up and show the Lacie Hard drive. Go to windows control panel and run add hardware program and search once. (if it hasnt mounted it will not find it) just let the search go through once and after it says can-not find hardware leave it open. Go to My Computer and open it, keep the window open that shows all of your drives. Wait about 4-8 hours depending on what you have going on (go to the movies or go to sleep) and come back and your lacie drive will be mounted. (THIS IS NOT THE LAST STEP- DONT GET HAPPY YET) This is whats going to burn your attitude to a new level. The Lacie Hard drive is SUPER un responsive. I advise opening just the main window and taking a look at all the folders and files you have on them. ( i solved mine by simply erasing the Video files. Final cut pro cache folders etc.) if you use your hard drive for things like editing video and audio then more than likely your drive is slightly corrupted (don't get angry) this does not mean its trashed, it means that there is a problem with file structure and a single or several files confused the hard drive. Once again your lacie is not trash. I used mine for video editing in Final cut Pro, and Audio in Pro Tools, among other things like saving photos and software, etc... Just take the time to simply delete what you know you dont need.. or even better, format the entire drive and it will be like new. Another step you can take in mounting your Lacie is to download Mac Drive 7, install it on a PC- not MAC, this process WILL NOT work on a MAC (none of these steps will work on a mac- Trust me, not matter what these nerds say, dont believe that it will- its going to cost you.) Install the Mac Drive 7 on a pc, run the Error Check and repair function and it will take about an hour depending on what you have on your drive and how many errors are found. and It will fix the drive. As stated previously - these steps will ONLY MOUNT YOUR DRIVE. Access to the files and folders on your drive will be very unresponsive. Basically if you plan on copying a movie to your desktop forget about it. 30Mb would take about 2 hours. 6Kb took close to 4 mins to copy from the lacie. You wont be able to back it up so forget about that too. Just follow the begining steps and find out what has done this to your Lacie (you know what it is!). As stated previously- I used my LACIE D2 qudra 500 GB Hard drive (that is only 6 months used) for average things like downloading, uploading, saving, etc... the same things you do, Plus I ran Final Cut Pro, Pro Tools, Logic Pro, and a S**T load of other programs on this drive and what confused or "Corrupted" my lacie and made it BLINK, CLICK, and make STRANGE
SOURCE: external hard drive
500Gb Lacie D2 Quadra with the same problem of flashing led and not
mounting on the desktop (Mac G4 Mirror), traced to the power supply
(57w) going down on power, both 12v and 5v supplies are available but
the main power to run the drive drops to below an adequate output,
hence the clicking and whirring evident from the drive with
simultaneous flashing led.
Testing with another Lacie power supply (250Gb D2) this time a 34w unit
got the drive up and running, however, and this is the reason for this
post, this lower power PSU failed a week later whilst waiting for a
warranty replacement from Lacie (5 weeks and still waiting for the new
PSU from them. they have no stock)
Message for all Lacie D2 users, check the power supplies first, test
with another Lacie PSU, do not run the drive on a lower rating (34w)
PSU it will fry it and leave you with another failed power supply.
If you are in a tight spot use the temporary power supply to move your
data to another drive and get the correct 57w power supply before
running the drive again.
Don't do as I did assume any Lacie power supply will run any Lacie hard
drive, they won't, fortunately I had a second back up, but am 2 drives
down and no new PSU's available to buy anywhere.
Try and purchase another spare 57w power supply, something all D2 users
should do for long term security, as these do not seem to be very
reliable and getting warranty support from Lacie on these is currently
impossible.
The lack of 57w power supplies from Lacie and its distributors across the world is surely a warning to be noted!!!!!!
Buyers beware!
SOURCE: What power supply does Lacie 160GB external hard drive use?
Although not sold at Best Buy™, there are available adapters/cables to
make this transfer possible. I recommend using a search engine to find
"firewire to usb." Hopefully this will give you the results you need.
Rhiecksboy
SOURCE: My mac is not recognizing my Lacie 1 TB, it
I had the same issue -- turned out that power supply was going bad so the drive wouldn't spin up all the way; this could explain the strange noises you're hearing. I put in a support ticket with LaCie at their website and they sent me a new power supply at no charge (I was within the warranty period, I think).
