Question about Canon ES10V Camcorder
Video camera classes
Do you know if there is any short classes on how to use your video recorder in melb? I have had this "canon uc-v100 with image stabilizer 72x digital zoom" for 10 years and almost new as i have hardly use it. I have taken shots but don't even know how to view it on tv or pc. Just have been too busy with other things and now I am getting interested into working on this video cam.
Thanks gemma
Posted by 99cents007 on
Tony Parsons
  • Canon Master
  • 6,316 Answers
Check with your local community college
Posted on Aug 03, 2017
5 Related Answers
Anonymous
SOURCE: PowerShot A610 Lens malfunction
What the problem looks like The problem can take any of several forms, but all involve severe color shifts and/or severe distortions of the image. The images below show two examples (courtesy of Konica Minolta) of what the problem might look like, if your camera falls prey to it. In the early stages of the problem, the camera may still capture recognizable images, but with a washed-out appearance and a strong magenta or green tint. What products may be affected? Quite a number of products may develop this problem, including digital cameras, camcorders, and even PDAs (Personal Digital Assistants) that incorporate an image sensor. The following is a list of affected models by various manufacturers that we are presently aware of. We will update this list as new information becomes available. We recommend that you check the site regularly for this and other breaking news.
Posted on Sep 25, 2007
Anonymous
  • 64 Answers
SOURCE: Zoom Lens Problem
Sorry there is something wrong with the mainboard when we get these at work thats usually what it is sometimes on the newer models the flex comes loose but not on this one if you have a warranty send it in if not its not worth fixing sorry
Posted on Dec 25, 2007
Anonymous
  • 73 Answers
SOURCE: my canon video camera won't show video
OK THIS IS FIXED FOR FREE AT WWW.CANON.COM THIS IS A CCD. THEY NOW ALL ABOUT IT
Posted on Mar 02, 2008
TampaNative
Frank Fernandez
  • 778 Answers
SOURCE: camcorders
You can connect your Canon analog camera to your PC with the "cinch or S-Video" cables that came with it when it was new. Your Digital PC will have to have a compatible video card for the above mentioned connections. You can upgrade your Graphics Card if your PC's isn't compatible.
Posted on Jun 06, 2009
Anonymous
  • 532 Answers
SOURCE: Problem with Zoombrowser EX Digital Camera
This is a registry error. Try this: type regsvr32 quartz.dll in the run box on your computer. That would be: Click start, run, and then type this into the box.
If yoou do this correctly, you should see a message that it was registered correctly.
Try the program to see if it fixed the issue.
Posted on Jan 04, 2010
Video noise with canon uc x50
Are you lighting the subject well?
Not using any high gain modes? Recording at highest quality?
Oct 25, 2013 | Sony Handycam Video Cameras
Tip
Using a Document Camera in the class room
There are times in a classroom when using a regular projector or transparency projector just aren't the right tools for the job. In these cases you might consider using a document camera to project a paper on to a screen. The main benefit for this method of presentation is when you are presenting something that you will be drawing on, but there are also other benefits that it can be used for.
There are many features on document cameras that many beginning users don't know about or take advantage of. Taking advantage of the features can make you a better presenter and a better teacher.
Document cameras are able to be used as a live camera. If you have students making a lot of presentations and if your document camera has a swivel head you can use it to project the student on to the board. This will make it easier for students in the back of the room to see the presenting student.
Using the document camera as a live camera can have more benefits than just projecting on the screen. Most document cameras have the ability to capture images, this can be useful for documenting a students progress and projects. It can also be used to show parents how their child is doing in school at parent teacher conferences.
Some students I have found have a fear of presenting and prefer to record themselves and play the video to the class. With the document camera you can record the students presentation and then play it back in class.
It is unavoidable that occasionally students will miss classes and it can be very difficult for them to catch back up especially in math and science courses. Using a document camera you can record your lessons and create short videos that explain concepts just as it was presented in class. These videos can be useful in catching up students because they will see the video just as if they had been in class.
A side from helping students to success in class document cameras can be used to engage students in class. In social studies a blank map can be placed under the camera and projected on a white board, students can be called up to write on the board. The same can be done by projecting lined paper so they can write straight, or the math equations to be answered on the board.
Using a document camera in a classroom the options are endless. There are hundreds of things that can be done and there are always more to be discovered.
on Feb 10, 2014 | Office Equipment & Supplies
My Canon PowerShot SX230 HS cuts off after 10-14 seconds of recording. A yellow exclamation mark appears and shuts the video off. A green light flashes and says the word busy at the bottom of the screen....
There may be other causes for your experience but I am thinking of two and these are:
  1. The memory card - video recording is best achieved with a card of Class 4 or higher. Anything less will pose problems.
  2. Settings on camera auto-timeout - check to make sure the auto-time out is set to default.
Aug 20, 2013 | Canon PowerShot SX230 HS 12.1 MP CMOS...
I own a Canon EOS Rebel XTi. This camera is unpredictable; i.e., I never know when it will decide not to record an image. I have reset it many times to the manufacturer's default settings, and then it...
Okay at least the memory card isn't locked or it wouldn't be taking any pictures. Couple things one is did your format the memory card before using it? Do you format the memory card after downloading pictures to the computer? Do you just unplug the USB cable or remove the memory card from a card reader before doing a safe disconnect? What I believe is that you delete and delete and delete pictures from the card and it's not corrupted with a lot of useless data residue. Short answer to your problem is format the memory card in the camera you intend to use it in. Have a great day
Dec 26, 2010 | Canon EOS Digital Rebel XTI Digital Camera
Can an old film sigma uc zoom 70-210mm lens work on canon digital cameras
In short, no. Not without an expensive adapter which includes a corrective lens (which also reduces the optical quality). Even then, the lens will be fully manual only and might only be operable at the widest aperture setting.
If your Canon uses the APS-C sized sensor (all except a few highly expensive professional full-frame models do) then the 70-210 lens will produce a cropped image as if you were using a 112-336mm lens, so it may also be less useful to you.
Aug 14, 2010 | Canon Cameras
Video only recording for very short periods, using high quality fully charged batteries
I don't know what camera you have but, as a general rule, to record video for as long as you want, you need to use a class 6 card.
Feb 27, 2010 | Cameras
Camcorders
Jun 06, 2009 | Canon Video Cameras
How to over come error code no. 2881
Good day,
I like to know how to connect my canon camcorder UC-V100 being analoge to my computor
thks
Jun 04, 2009 | Hitachi DZ-MV550E DVD Camcorder
Canon ES10V Camcorder Logo
Top Canon Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Lawrence Oravetz
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
