If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses.
If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Hello &
Welcome to FixYa
The problem
is with the water inlet valve that needs replacement. You can also test the
valve before replacement, if the valve tests fine then the float switch located
at the bottom of the unit needs to be tested and if bad it is recommended to
replace it. Please get back to me if you have any
other questions.
Kevin
