Nokia E5 Cell Phone Logo
A
Anonymous Posted on Jun 27, 2011
I have dropped my E5 into the bath - Nokia E5 Cell Phone
Anonymous
Level 3:
  • Nokia Master 32,281 Answers
  • Posted on Jun 27, 2011
Anonymous
Nokia Master
Level 3:
Answers
32281
Questions
Helped
7905915
Points
102259
Immediately remove the phone from the water,turn off the cell phone remove the battery and SIM card. When you have driedthe cell phone by putting in a warm sunny place for several days or in front of a warm fan heater for several hours then reassemblethe phone. Hopefully it will work properly but if does not work then it isfaulty and you need a new cell phone.
vimal
Level 3:
  • Master 340 Answers
vimal
Master
Level 3:
Answers
340
Questions
0
Helped
68675
Points
1121
Dont turn it on just remove your batteries sim card, memory card and dry it in sunlight for a day and check again for any water inside the panel. dry it with hair dryer.
How to clean a whirlpool bath tub
There are three main things to tackle when cleaning a hot tub or whirlpool bath. Those things are:
1. Bacteria
2. Grease
3. Grime and dirt
To address all three of these issues you'll likely need separate products. There are liquid versions of the degreaser and cleaner, and there are tablet versions for sanitizing.
Simply fill up the whirlpool bath with warm water, put the cleaning liquid in the cleaning outlet (or if you don't have this, just pour it into the bath). Put the tablet in the bath and then just run it.
This should do the job.
Pure Spa Whirlpool Bath Spa and Hot Tub Cleaning Kit
Why does my geberit bath waste plug leak water?
It's adjustable. Remove the drain lever from the side of the tub. Now you can withdraw the whole drain assembly. Clean it well, then reinsert it to see if that fixed the problem. If not, try adjusting it longer.
2answers
Bath will not fill up
One of two these would cause this, either something is under the plug and not allowing it to drop down all the way or the rubber seal is worn and needs to be replaced. Either way you need to remove the plug and check for anything that would prevent it from dropping , if nothing is found replace the seal or plug.
I dropped my phone in the bath will it ever dry out and work again
try putting your phone in dry rice it will draw out the water and help speed up the process
2answers
My Nokia e-5 can't be started..i don't know why.. but it's always vibrate when i'm try to switch that open.. i just bought it 3 week ago..please help me...
just remove the batter and reinsert it again and switch on the mobile, it will on. make sure its charged. i was also having the same problem.
2helpful
My phone dropped in the bath!
you might have some water damage. take the phone to a repair centre
I dropped my samsung E840 phone in the bath 2days ago and the screen went black but the phone still lit up...the screen is now back to normal but goes black every now and again and the numbered buttons are...
Recent phones dont agree with water to much, but what you can do is pull it apart and spray it all with a electric cleaner, but if you have insurance on your phone that would be the best way to replace it, warranty wont cover it. you could try to hard reset it but most likely wont work still
Drop phone in bath
The only thing you can do is dry it out more with heat(hairdryer). Remove the battery while doing this. If you still have the same problem then yes, unfortunately the keypad has shorted out.
Please remember to rate this answer.
Dropped my sonny ericsson W800I in the bath
A basic equation is : Water + Phone = Dead Phone Warm water and a phone is really bad news, the level of corrosion inside the phone after a warm bath is significant. You could try to disassemble the phone and clean it on the inside, but you should not get your hopes up. In many cases, repairing the phone (after water damage) is much more expensive than getting a brand new one.
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
