Question about Integra DTR-8.3 Receiver
SOURCE: how do reset receiver back to factory setting
■ Initializing PRESET
Use this feature to reset all the parameters of this unit to
the initial factory settings.
Choices: CANCEL, RESET
•Select “ANCEL”not to reset any parameters of this
unit.
•Select “ESET”to reset the parameters of this unit.
Posted on Apr 16, 2009
SOURCE: Low to no volume output from Integra DTR-5.2 receiver
most higher end integra's have a input level adjusment or input selection for each and every input. Perhaps you are not on the correct input, go to onscreen programming and check out the input level and input select - also try the tape in another input like tape 2 or cd. It will not hurt the receiver for a test. Also, if you are using the cheap cables from the manufacturer - try a pair of cables that you know work or go by some. BTW, you don't need to spend $40 for cables order them online through amazon or other store. Gold / sliver plated oxygen free are best.
Posted on Jun 30, 2009
SOURCE: I have an integra dtr 7.7 receiver which when
obviously a short somewhere in the system....
you know what i would do?
pray to god you are still under warranty! XD
its a beautiful machine....
Posted on Jan 08, 2010
SOURCE: Integra dtr-6.3 receiver: Red standby light
your receiver is having a power problem. The power supply board is defective that's why the receiver won't power up. Its receiving power but it cannot transfer the current to the necessary part of the receiver because a capacitor, diode, etc may have been faulty. Until these bad components are replaced, the capacitor might not come on.
This may have occurred as a result of power surge/irregular power supply/excess power supply entering into the unit. This is usually common with receivers and electronics as a whole.
If you know about electronic repairers, I would suggest that you open the receiver and read the power board/panel with a meter, detect the bad component and replace it.
But f you don't know about electronic repairers, take the reciver to the nearest repairman to fix the fault for you.
I wish you good luck.
Posted on Dec 02, 2010
SOURCE: I have a Integra receiver
NO sound at all? That would be odd as its internal FM receiver is independent of any user connections. I'd work on getting FM to work first, then move on to more complex issues. To reset the AV receiver to its factory defaults, turn it on and, while holding down the [Video 1] button, press the [Standby/On] button. "Clear" will appear on the display and the AV receiver will enter Standby mode.
The manual is here:
http://www.retrevo.com/support/Integra-DTR-6.6-Receivers-manual/id/550ag000/t/2/
Posted on Dec 26, 2010
Aug 09, 2014 | Integra DTR-5.2 Receiver
Mar 26, 2014 | Integra Onkyo Rc-711m Dtr-4.9 / 5.9...
Feb 02, 2014 | Integra DTR-5.1 Receiver
Aug 24, 2013 | Integra DTR 5.6 Multi Media Amp
May 17, 2012 | Integra Audio Players & Recorders
Dec 26, 2010 | Audio Players & Recorders
Jul 20, 2010 | Integra DTR-7.1 Receiver
Jun 30, 2009 | Integra DTR-5.2 Receiver
Jan 17, 2009 | Integra DTR-9.1 7.1 Channels Receiver
Nov 02, 2017 | Integra DTR-8.3 Receiver
1,055 people viewed this question
