SOURCE: Ice dispenser not working
Scorpio, remove the ice bin itself, dump the ice and see if you can move the bin auger by hand by turning the actuator in the rear. If the bin is ok, with the door open and the door switch held in see if the auger motor is turning when pressing the ice lever. If it's not turning the next logical step is to see whether the auger motor is getting voltage when calling for ice. Make sure the door switch is closed. The part number for the auger motor on the posted model is wr60x0202. Hope this gets you going..Catriver.
Hi Wilday1, Sounds like you have a possible defrost malfunction. In this case the Ice maker motor may have become iced and cannot turn the auger. Tell me if you have frost buildup at the back of the frezer and ice crystals on the auger drive. If you do , then you need to remove the Ice makers motor and allow it to thaw and defrost itself. be sure it is completely dry before putting it back in. I hope this helps.
SOURCE: Ice Maker Overflowing
i would recommend changing the water valves as they may be sticking or leaking now you can take the icemaker loose get a small baby bottle short the terminals to cycle water fill catch it with the bottle and see how much water it dumps should be about 4 ounces if the valve leaks will over fill the ice maker over a period of time say the valve is leaking a few drops at a time and the bail arm has the icemaker shut off because its touching ice in the bin but the water just keeps dripping down the fill tube till it runs over did you replace the whole icemaker or just the motor module
SOURCE: KitchenAid Superba ice maker not dispensing ice
the problem is that the bottom piece is missing from the ice maker housing. i have the same problem and im looking for that peice
SOURCE: Ice dispenser won't turn on, and the ice maker won't make ice.
If you have a whirlpool icemaker inside of your freezer (I've read on other posts that whirlpool ice makers are installed in various makes and models), there is a white cover over the ice maker (it's square). Remove the square cover with your hands or stick a flat head screwdriver in the side until you can pull it off.
Once the white square cover is removed, you should see a white wheel with gear teeth. In the middle of the white wheel is a plastic snap that should be holding it in. I noticed that one of the little plastic snaps was broken...which caused my "no ice" problem. A simple test is to push the white wheel toward the icemaker. If the wheel starts turning, you have found the problem.
Because the little plastic snap tab was broken off, I was able to pull the white wheel out completely.
You see, behind the white wheel are metal contacts that need pressure for the ice maker to work. Without the center plastic snaps holding it it, the pressure is gone...and so is the metal to metal contact.
I previously called Whirlpool, searched all of the web...to no avail. Every other solution was "check for ice blocking the water tube" or "replace your water filter". That's all balony. If your regular water dispenser is working, you don't have an ice problem. And if your water dispenser is working, you don't have to change your filter either.
If you realize that the little white wheel is the culprit, just google "whirlpool module" and you will see it for sale. I found one on ebay for under thirty buckaroos with free shipping.
Hope this helps.
