Question about D-Link 802.11g Wireless Router WBR-1310 (WBR1310)
Forgot the network security key (or my password) for D-Link WBR-1310,54Mbps,802.11g Wireless G Router,P/N:CWBR1310ANA..B1, S/N: F3RO183002877, MAC ID:001E58377258, FCC ID:KA2WBR1310B1, IC:4216A-WBR1310
Posted by ylakusta on
Hasan AL Mahfuz
    New Friend:
  • 85 Answers
Reset the router to factory default. if you are confident. it is a small button at the back. press it coupel of sec then release. Then you can reset the password.
Posted on Jun 26, 2011
How do I make my wbr 1310 router secure
Type 192.168.0.1 on the address bar of your browser and open up that site. If its asking you to login, make use of "admin" for the username and password. Next, click on wireless setup and then click "manual wireless connection setup" then enable the Wireless Security Mode and it may ask you to setup your wireless network key which will be the one that your going to use if your going to connect a PC to your wireless network.
Aug 27, 2011 | D-Link 802.11g Wireless Router WBR-1310...
Forgot my network security key
If you forgot the security key to your wireless connection, connect your pc (or mac!) to the router with an ethernet cord. In the web browser (like internet explorer, firefox, etc) type in 192.168.1.1- you should get a prompt asking for user name and password- by default the user name is admin and the password has nothing- that should get you into the router. Once there, click on the link for wireless and then wireless security- your network key would be listed right there.
I’m happy to help further over the phone at https://www.6ya.com/expert/susan_42b401e0b1603d8a
Nov 10, 2010 | Lands Phones
How do I secure my D-Link WBR-1310 wireless router?
You can follow these steps in enabling wireless security on your router and do this steps using a computer wired to the router since once you save the settings your wireless network will be secure.<br /><br />1) Open the internet browser and type the address 192.168.0.1 to login to the router. The default username is "admin" and leave the password box empty.<br />2) Click "Wireless Settings" on the left side.<br />3) Select the Security Mode ,Enable WEP Security.<br />4) Select the Authentication ,Shared Key.<br />5) Select the WEP Encryption , either 64-bit or 128-bit.<br />6) Select the Key Type ,HEX (only A-F and 0-9 number allowed) or ASCII (all number and character allowed).<br />7) Enter a WEP key as your security password to login to your wireless later.<br />8) Press Save Settings to save all settings changed. Reboot the router.<br /><br />
Aug 24, 2010 | D-Link 802.11g Wireless Router WBR-1310...
WBR 2310 wireless stops working.
Please reset the router and also remove the network from the devices and reconnect with the password.
for more visit www.leadingpcfix.com
Feb 13, 2018 | D-Link RangeBooster G WBR-2310 Wireless...
Changing Wireless network password without resetting the router
For that access your router with
http://192.168.1.1
or http://192.168.0.1
if you cant able access it then reset it
Press RESET button for 10 seconds it is in back sid of router.
then access above link.
type user name "admin' and password as "admin' or blank or "password'
then go to wi fi security first configure your router as WEP then go to wi fi security in advancwed then set WEP key it is your password to connect wi fi .
Aug 13, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Forgot D-Link 1310 wireless password - how do I retrieve it
What password? Are you referring to the WEP or WPA-PSK password? If yes, I would like to inform you that no one could give you the exact WEP or WPA key. Even if you check the utility of the router.
What you need to do is to reset the router to factory default and then reconfigure the router. That's the only way that you could do in order to set a new password.
Have a good evening!
Aug 03, 2009 | D-Link 802.11g Wireless Router WBR-1310...
D-LINK WBR 1310 ROUTER
Go the router setup page, 192.168.0.1, type admin as the user name and password as the password (default, if you have changed these use your login info).
Then on the wireless page change the SSID (router name).
You can also add a security key on this page.
http://support.dlink.com/emulators/wbr1310_revA/wireless.htm
more info from D-Link:
http://www.dlink.com/products/support.asp?pid=474&pv=96&sec=1
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Apr 12, 2009 | D-Link 802.11g Wireless Router WBR-1310...
My wireless router is not secure
access your router with following link
http://192.168.0.1
or
http://192.168.1.1
then type username and password "admin" also some time spassword is blank
then go to wireless security then enable it .
then set encryption key ans also set ssid
confirue your router as WEP
Apr 09, 2009 | D-Link 802.11g Wireless Router WBR-1310...
My PS3 is asking for a wpa key code so I can go online?
If you dont know your wpa network key try to reconfigure your wireless network again.
Access the configuration page of your router.
>Type on the address bar 192.168.0.1
>On login type Admin leave password blank. if you set up a password or the login page use that one.
>Once inside the Dlink Page
>Clik Setup and on the left side click wireless setting.
>If given the option to click on manaul wireless connection setup click on it.
>Once you have the wireles window
>try to change the network name to a new one and scroll down
>Under security choose WPA security (enhanced)
>Scroll down and under the Passphrase type in your new network password or security key and confirm it.
>Click on Save Settings
>If it asks you to reboot then reboot it, if not, its ok.
Jan 26, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Wbr-2310 d-link
Follow these steps:
1.Type 192.168.1.1 in Internet Explorer.
2.You might have to put Admin password to access the router which is usually admin and password field blank.
3.Go to wireless setting and change the password.
Dec 23, 2007 | D-Link RangeBooster G WBR-2310 Wireless...
D-Link 802.11g Wireless Router WBR-1310 (WBR1310) Logo
194 people viewed this question
Top D-Link Computers & Internet Experts
Mike
RockTheHood
k24674
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
